Question about Parrot Cell Phones
I have bought a car with A Parrot 3200 LS which I don't use and which distracts me when driving by flashinh. How do I turn it off please?
Posted by John Packer on
5 Related Answers
Anonymous
SOURCE: Parrot 3200 Colour LS
My Parrot came with the default code 1234
Posted on Jul 27, 2008
Anonymous
SOURCE: 3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Posted on Jan 03, 2009
Anonymous
  • 89 Answers
SOURCE: ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Posted on Feb 26, 2009
dancandoit
Daniel Boyes
  • 436 Answers
SOURCE: when I try to pair my Nokia N97 mini to my 3200 LS
firstly you need to go to settings / paired devices & delete any old pairings, the go to settings / pair with phone and it will give you a code to enter. Now search for bluetooth devices on your phone and enter the code when prompted.
Good luck.
Posted on Nov 15, 2009
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: how do i pair my
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Posted on Oct 08, 2010
How to turn on parrot 3200
The kit should automatically switch on with the cars ignition, if not you will need to make sure there is power on the red wire and the orange wire.
Dec 31, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have paired my phone with 3200 ls color witch was sucssesful but my contacts don,t appear in phonebook
this depends on what phone you have, you can try marking all your contacts and them sending via bluetooth to the parrot or you may have to send contacts one by one. try parrot.com for compatability.
Jan 18, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Parrot 3200 Ls doesn't cut out radio
problem is the 220 has an amplefier in boot the controls the radio, unless proper leads that connect there are used to interupt the radio when call happens it just some thing u have to put up with or buy the lead, try autoleads.com or look on parrot web site for the right leads
Mar 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Cell Phones Logo
Top Parrot Cell Phones Experts
Marvin
Marvin
ray gallant
john h
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
