Question about Creative Labs ZEN V Plus MP3 Player
I have a creative Zen 2GB & when I turn it on it has to rebuild libraies and then once that is complete it freezes on the one song & I cant turn it on or off
Posted by odteresa on
Anonymous
  • 3 Answers
Ok just fixed mine by pushing pin into reset hole. Hold play button turn zen v back on format player. yes you will lose your data but its better than buying a new mp3 player. download zen firmware update plug player in and update. This problem is caused by a corrupted file so the only way to fix it is full formate.
Posted on Sep 16, 2009
Hi, My Creative ZEN has frozen up. When you switch it on a 'rebuilding' screen is displayed and once that has run its course the last song that was playing is displayed as playing but does not play &...
First of all, I hope you mad a backup of it's content, becouse there is
no other way, it need to be fomated from it's service menu.
1. Make sure bthat your Zen is turned off and has a full battery.
2. Press and hold the Play/Pause button and Back/Options button simultaneously.
3.
The Recovery Mode screen appears when the player, and three menu items are shown: Clean Up, Format and Reboot.
4.
Format your ZEN and then do a clean up.
5. When done reboot.
6. Hook it up to your computer an reflash to the latest firmware, you can download the tool here to flash your firmware:
http://ccfiles.creative.com/ManualDn/Applications/PDE/10398/0x8CCCF7FC/CT-RT_PCAPP_2_00_05.exe
Jul 28, 2010 | Creative Labs Zen Touch MP3 Player
My Creative Zen 4gb will not appear in Itunes ?
To convert iTunes music for Creative ZEN, you shall download TunePat audio converter from a website. You shall run TunePat audio converter and iTunes simultaneously and set TunePat as the default burning drive for iTunes. You may also create an iTunes playlist to hold the songs you want to convert for Creative ZEN.
Once the conversion is completed, you can find the MP3 or WMA songs in the output folder, with all ID3 tags and album information intact. Then you can open Creative MediaSource and sync the converted to your Creative ZEN player.
Take care.
May 14, 2010 | Audio Players & Recorders
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Creative Zen V
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Nov 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Help frozen up zen vplus 4gb
I had the same repeating problem with my Zen V Plus 2GB. There is a tiny hole on the left side of the player, underneath the on/off switch. Stick a paperclip in there and press gently to reset your player. I lived for 6 months letting the battery wear itself out before I discovered this reset hole. I finally found the offending piece of music and deleted it from the player. I haven't had any problems with my Zen freezing since deleting that song. Pay attention to whether it always freezes on the same media, that might be the source of your problem.
Hope this helps!
Jun 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Why zen sleek photo won't download music
i have a zen sleek and every time i turn it on it says rebuilding library. It completes this but deletes the last album etc that i put onto it. back down to the last album i put on before it started doign it. So i cant put anymore mousic on becuase it deletes it..Any Help?
Apr 17, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Creative ZEN 20gb (Model **. DAP-HDD015
I dont know but I read somewhere in Creatives manuals or online that they recommened not filling up the device completely with media. Don't ask me why, if they give it to you you should take it but I'm not creative lol
Mar 10, 2008 | Creative Labs Zen Touch MP3 Player
Froze in the middle of a song.
Thank you thank you thank you a billion times, you just saved my life (well, at least my zen's). Did as you said, my Zen Touch 20GB is rebuilding it's library right now. Oh, now it's done. Everything's still there, awesome. Thank you!
Mar 03, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
