Question about Electronics - Others
HOW DO I REMOVE THE WRITE PROTECT ON MY 64GIG USB FLASH
Posted by Nomathemba Bikwa on
Dave O.
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
To remove the write protection, simply open your Start menu of your computer/laptop, and click on Run. Type in regedit and press Enter. This will open the registry editor. Double-click the WriteProtect key located in the right side pane and set the value to 0.
Posted on Sep 19, 2019
jimixclay
    New Friend:
  • 66 Answers
Write protect in flashdrive could mean chip problem if you cannot partition or reformat the usb drive..you can try usb low level format, partition application..be sure to back up files before doing so.
Posted on Sep 12, 2019
5 Related Answers
Anonymous
SOURCE: SD FLASH CARD -WRITE PROTECT
MAKE SURE THE LOCK IS NOT LOCKED ON IT
Posted on Jan 11, 2009
laikexpert
laikexpert
  • 281 Answers
SOURCE: How to remove write protect on my usb flash drive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flash drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 05, 2010
TommyRaudy
Tommy Raudy
  • 9 Answers
SOURCE: how to remove write protect from a usb flash drive
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Posted on Jul 14, 2010
Goldi Kunal
  • 187 Answers
If you have a write-protected flash drive that you need to access, it can be difficult to change it to allow you access, especially if it is a security-optimized flash drive. However, there are a few practical steps you can take to change the write-protection on a flash drive.
#1
Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
#2
Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not work.
#3
Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
Hope this might help
Thanks
Posted on Oct 07, 2010
Anonymous
  • 179 Answers
SOURCE: Genx usb flash 128 Mg
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Posted on Jan 18, 2011
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
WHAT IS WRITE PROTECT?
look on the side of the usb there is a little button that you push one way or the other to remove the write protect
Oct 27, 2012 | Kingston 4GB DataTraveler I Generation 3...
How to remove write-protect to my usb
just go google site and type password removal free software just download that software and run in your computer it will give how to remove the protectiong
May 12, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
how to remove write protected on my usb flash drive and i have mp3; when plugin into the usb hub it shows a problem occured during installation
May 04, 2008 | Electronics - Others
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Electronics - Others Logo
173 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
