Question about Canon Office Equipment & Supplies
Canon ir210, scanner does not return home and locks up. During copy, scanner tries to go home, and continous away from home. Makes a heck of a noise, scanner rails are clean, allen set on scan drive is tight, home sensor has been cleaned.
Posted by lgaato on
Anonymous
  • 168 Answers
Had this alot your a tech i assume ? if so replace the lens/ccd assy and the ip board if you have a scrap 210 replace the two together that will fix your prob
Posted on Sep 15, 2009
What year was Canon IR210 manufactured?
That model is pretty old, i havent seen one in almost ten years, i think is discontinued already
May 11, 2016 | Canon Office Equipment & Supplies
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
Hi
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon ir210s gatting error E100
that is a defective laser error code sorry
Dec 23, 2008 | Canon imageRUNNER 210S Copier
Continually scanning
Make sure the lock switch is in the unlocked position. The lock switch is on the bottom of the scanner. It sounds like something is preventing the scanning bar from getting to the home position. If the scanner was somehow locked with the scanning head being out of the home position, then the result would be what you describe.
Jun 25, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon ir210 problem
try to uninstall and reinstall the printer by going to (add remove programs ) in control pannel then restart pc and printer.
Nov 13, 2007 | Canon imageRUNNER 400V Copier
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
67 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
