Can I convert a procom heater from propane to natural gas? if so how?
You need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
