How can we enter OK botton without using remote control?
Posted by Jay-Ar Robert Sazon on
I have a durabrand DBTV1024 and it is locked and i dont have the remote that goes with it...please help me to get this tv
Hello
You can't unlock the V-Chip setting without entering into its service mode. This is actually a skilled work, and cannot be done without its remote control. If you have the remote control, entering into the s
This unit provided with the following SERVICE MODES so you can repair, examine and adjust easily.
To enter the Service Mode, press both set key and remote control key for more than 1 second.
Then set volume to minimum and press "0" digit on the remote control to unlock V-Chip and to set a new password.
From this proceedings, you can know that, without its original remote control, the set cannot be unlocked. Try to get it from the nearest Duraband authorised service center or from any electronic spare part shops at your town. OK.
ervice mode do the following>
Sep 30, 2011 | Durabrand DWT2704 TV
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
Hi
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
OK.
Jul 11, 2011 | Apex Digital Televison & Video
I broke my remote and i need to change my tv to av and ther is no botton on my tv that says av is it posiable to change it to av?
Hello
Without remote control you can't change its mode to AV. Buy one "Atlas OCAP 5-device remote control; by Universal Electronics. Emerson is listed to very short numbers of universal remotes, and this is one amoung them. The codes will be with the attached manual, and you can choose if from it. OK.
Jun 10, 2011 | Emerson EWF2703 27" TV
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
I need the code for a Panasonic pvqm2508 so I can program it using a GE universal control
try to program it by using automatic search process. press and hold set up botton till the light stands on ,press the device to pprogram then press power simultaneously .When your device responds press enter botton to strore the code.
Sep 06, 2009 | Universal Remote Control GE174Universal...
Remote
the intruction are at the back of the battery .
1 turn on tv
2 press and hold Code Search untill all device bottons light( they will all turn green)
3 press tv button. tv botton will stay on
4 press power repeatedly untill tv turns off
5 press enter and you are all set
repeat 1-5 for vcr , ect
Apr 01, 2008 | RCA RCR350 Remote Control
Programing dish network remote control for aiwa av-x220
You will have to call Dish Network.
800-825-2557
Feb 22, 2008 | Aiwa AV-X220
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
