Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My LCD Sony HD tv turns off after few seconds.
Sony Bravia LCD HD tv. All of a sudden one day turns off and the LED indicator on front panel started blinking. Remote will not work and the only way to turn it on is to unplug the main power and leaving it unplgged for 5-10 minutes. Later it will turn on but aftter few seconds turns off and LED starts blinking. Help will be appreciated. Thanks.
Anonymous
    President:
  • Sony Master
  • 1,779 Answers
You need the Inverter Board.
Posted on Sep 14, 2009
  • cas57242 May 26, 2011
    Did this fix the issue? My TV just started doing the same thing. If it worked, how much did the repair cost? Should I just buy a new tv?
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Klv-32u300a sony geting power on suddenly goving of
SONY-KLV32U300A
NO STEND BY LED NOT LIGHT
4V FROM POWER NOT FOUND
1helpful
Hey i just bought a new sony bravia hd lcd internet tv. and ever since like a month ago the screen would go blank and the volume would go out. the screen would only go out for a few seconds but its enough...
Tv it is having a problems,it is developing a power surges to their eclectronic boards.If this tv have this problems like 2 or 3 times black out in a couple hours of tv watching?Yes.This is a brand new tv?Yes,it should be return to the place where it was bought right away to exchange it for another tv,because this problems,will develope in to a bigger problems.The tv Tuner signal board,will evenually will dies completey.After tv life in usage for awhile more.Ur tv evenually get power only, indication LED power light up only,but no tv incomming broadcasting picture to tv at all.
1helpful
2answers
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
2helpful
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Sony tv, no pic or sound, lcd blinks
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
