Sony Cyber-shot DSC-W170 Digital Camera Logo
Posted on Sep 14, 2009
My sony cybershot dsc-s780 can be turned on but within 3 secs the screen goes black and displays the message "for use with compatible battery only" the battery is the one which came with the camera! coldaws,lancs
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
384
Points
My cyber-shot dsc s780 did the whole "Use with compatible battrey" thing and I gave it the ole Fonz on the side of the camera closest to the battery and it seemes to be working now. I'm certainly no professional, however, everything needs a good smack upside the head once in a while! :)
Anonymous
Level 1:
New Friend:
  • Posted on Apr 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
384
Points
Picture are cloudy and have horizontal white lines.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy. Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
Hi! I need help, my Sony Cybershot S600 suddenly stopped working, the screen is black.
Question edited for clarity and toss in some CAPS.
Question moved to model category.
They normally need dealer service.
https://www.google.com/search?q=sony+cybershot+s600+black+screen
E:9101 shwos on the screen on DSC-T70 sony cybershot
Follow these steps:
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
1helpful
2answers
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Sony Cybershot DSC-T200 dropped, screen black so
the display is been broken...you can get the one from customer service...
1helpful
Compatible Battery error message
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
3helpful
I have a Cybershot DSC-S780
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Broken LCD screen sony DSC-S780
If you do a Google search for 'digital camera parts' the first listing is a website that can help you. The LCD is $50 with shipping, and takes about a week before it is shipped as it is a special order item. The website name is: Darntoothysam com
How do I know this? I own the business, that's how. We specialize in LCD and lens repair for affordable prices. If we can help please let us know.
Thomas D.
Owner, Darntoothysam com
3answers
I have had my camera for over a year now without a problem. It is a Sony Cybershot 7.2 Megapixels. Everytime I turn it on a black screen and the message - "For Use with Compatible Battery Only"...
Hi
There is a sentence which i cannot figure out the your wrote in your initial description of your poblem. I think it is meant to be the error message you are getting here is what i read as part of
""For Use with Compatible Battery Only&quot"
Can you try and post it again. From your response i still have te suspicion it could be the batteries, but your error message will help.
Regards
Jul 16, 2008 • Cameras
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
