Hi. I need Urgent Help , i have creative inspire M5300 , i dnt have volume controlr of that sound system so i want to bypass that volume controler kindley plz help
SOURCE: Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
Posted on Jun 02, 2009
SOURCE: remote volume control needed for Creative Inspire 4.1 4400
Dear sir
I brought sound system, but unfortunately I miss place volume control, I would like to ask suggestion without volume control could i operate sound system....... could i get seprate part to buy from delers or mfg.
please advice.
Thanks
[email protected]
Posted on May 02, 2010
SOURCE: I use Creative 5.1 inspire
Simple one - uninstall sound driver - reinstall. Typical one - Google your sound driver find that is there any updated one for windows 7?. Download and install. It will work. Sometime (very silly) connecting ur device properly also work. Thanks
Posted on Dec 09, 2010
SOURCE: my sound card doesnt work
hello, which one of there sound card is yours, try to download the win 7 drive under this link and see if it will work.. "http://support.creative.com/Products/Products.aspx?catid=1" Thank you for using Fixya
Posted on Mar 05, 2011
SOURCE: Creative Inspire M5300 center speaker
if your computer came with a motherboard disc the sound drivers could be on it have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 10, 2011
Mar 30, 2014 | Audio Players & Recorders
Feb 07, 2013 | Creative Labs Inspire 4400 Computer...
Sep 17, 2011 | Creative Labs Sound Blaster Live! 5.1...
May 03, 2011 | Creative Labs Inspire 5300 Computer...
hope this helps
Apr 10, 2011 | Creative Labs Audio Players & Recorders
Jul 09, 2010 | Creative Labs Inspire 5200 Computer...
Aug 17, 2009 | Creative Labs Audio Players & Recorders
Jul 06, 2009 | Creative Labs Sound Blaster Live! 5.1...
Jul 01, 2009 | Audio Players & Recorders
Jun 02, 2009 | Audio Players & Recorders
46 people viewed this question
