The engine run fine last year at 5600 rpm. i did not winterize it.this year and it was hard to start.when it started the motor would only run at3800 rpm. so i had carbs boild out and new kitts put in them and new plugs and it didnt change a thing. the motor runs fine out of water, but in water and under a load it has a vibration and runs rough and still runs at 3800 rpm.can you help me with a solution please?
Did you change your fuel? If you are trying to use the same fuel from last year without being stabilized then that would cause your problem. I know that you already had your carbs cleaned but it sounds like something els got plugged up in them. If you have fresh fuel then I would take the carbs back apart and check your jets in the carb to ensure that there is nothing obstructing any of the orifaces in the jets. I am a boat mechanic and I have had to take carbs apart 2-3 times sometimes if they were varnished really bad to make sure I got all of the gunk out.
Moy 05 50 hp yamaha cleaned the carbs it idles great but taking off it boggs down then picks up but wont run past 4000 rpm
