As batts get older they take longer to reach full charge.
There may be a problem with a cell or maybe or a bloc
Batts are made up of sets of cells which make up a bloc.
eg 6 cells = 12 V bloc
Most UPS units have more than 1 bloc inside.
Standard batts can last about 3- 5years, it all depends on use, temp, cost of ups, and type of batt.
Some ups units allow you to check the batts with sofware, 1 other thing you can do is... with the ups powered up and running,do a test by connecting a lamp to the ups and failing the supply, for a short time say 3mins this will test the batts can work on load.
Before you do this make sure your critical load is not powered up.
Hope this helps , let me know by voting, thanks for using FixYa.
