Question about Sansui Televison & Video
My sansui g 5700 heating up so quickly and the left channel kinda distorted tone control not working on this channel. Any idea what could be the culprit? Thanks
Sansui G 5700 heating up quickly
Posted by Ed Gaviola on
5 Related Answers
Anonymous
  • 1665 Answers
SOURCE: sansui 32 tv where are controls such as contrast etc
Specs:
http://cnet.nytimes.com/direct-view-tvs-crt/sansui-dtv2760/4507-6481_7-32722198.html
Posted on Feb 12, 2008
Anonymous
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
Anonymous
SOURCE: Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
I need help to sete my remote for my SansuI T.V codes please thanks.
Posted on Dec 18, 2008
Bob Citizen
  • 520 Answers
SOURCE: Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Posted on Jan 07, 2009
CiNi
  • 144 Answers
SOURCE: Innovage Jumbo Universal Remote Control Codes for the Sansui VCR
Hi there, This should be the PDF file with all the codes you need. Hope this helps!
CBR2009
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Posted on Jul 24, 2009
Quad 33 chanel bad sound when playing music
As you know that the right is good you can compare that with the left. First look around for burnt resistors or damaged parts.
The next thing to do is with an insulated tool poke the two channels to see what buzz sound each channel makes. You should quickly find the distortion section with this method.
Mar 07, 2014 | Quad Audio Players & Recorders
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
I have a 1975 Sansui Integrated Stereo Amplifier and Left Channel on System A & B are faint and Tinny as if Left Channel in System went out. I swapped speakers from right to left channel and same...
It's likely there is a fault on the power amp. This is located on the heatsink. A visual check inside the unit might be what you need. Look out for blown parts, bulging capacitors or burnt components. Remember the two channels are generally separate and identical. So identify the two channels. Work back from the speaker sockets if you can't tell. Then compare the left channel parts with the right side components. If it looks odd on the left compared to the right you have found the problem.
Feb 14, 2018 | Sansui RZ-5300AV Receiver
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Apr 24, 2009 | Marantz PM-15S1 2-Channel Amplifier
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Televison & Video Logo
32 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
