Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
My Maytag gas wall oven (about 9 years old) ignites when I turn it on, heats to about 250 degrees, then loses heart; we smell a puff of gas (not continual, it obviously knows to shut off), the flames in the broiler tube (whatever that is) vanish, and then the temp goes back down, although the glowing igniter element still glows. Should we ditch it, or try to get it fixed? Thanks!
  • 142 Answers
Sounds like flame failure device can very in price
Posted on Sep 14, 2009
6ya staff
SOURCE:
The broiler does not turn on in my Maytag free standing oven. The ignition light glows but no flame comes on. You can not smell any gas. Any suggestions?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 16, 2011 | Maytag Ovens
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
The lower heating tube on my maytag oven. model # mgs5770adb , will not stsy lit, it seems to puff off and on. and i smell gas. what do i need to check.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 23, 2010 | Ovens
My gas oven heats very slowly and sporadically. It often smells like burning plastic when heating. The oven is about 9 years old and did not have this problem until recently. What could be wrong? Might...
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
Jan 29, 2018 | Maytag CWG3100A Gas Single Oven
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 13, 2010 | Maytag Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Oven not igniting
Very common problem, the ignitor or glow coil heats up but no gas comes out. For me for the last 12 years this repair has always been a weak ignitor. Call your parts store with the model number and check prices on the exact part and on any generic ignitors for this unit. Replace the ignitor and this should do the job. This can be a bad valve not letting the gas through, but again I have never seen that and I replace 4-6 ignitors a week. Good Luck, Appliance Specialists.
Dec 15, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
304 people viewed this question
Top Maytag Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
