In the morning the display was coming half & the screen picture was not clear. The dispay screen was showing teh message & gallery option on the top. Tried to switch off the set & check but failed. Later after 2-3 hrs the screen i sshowing white with no display. What is the solution and why does it happen?
its cost is 19.99 dollars.
Product MPN
MPN
N72
Key Features
Network Type
GSM 900
GSM 1800
GSM 1900
GPRS
EGSM 900
EGSM 1800
EGSM 1900
Style
Candy Bar
Design
Mobile
Installed Memory
20 MB
Connectivity
Bluetooth, USB
Display
Display Size
176 x 208
Screen Type
262K Colors (TFT)
Memory
Installed Memory
20 MB
Expansion Slot
Multimedia Card
RS-MMC
Technical Features
Antenna Type
Integrated
Connectivity
Bluetooth
USB
Input Method
5-Way Navigation Pad
Talk Time
3.58 Hours
Standby Time
260 Hours
Digital Camera Resolution
2 Megapixels
Digital Camera Zoom
20x Digital Zoom
Other Features
Messaging Formats
SMS
MMS
POP3
SMTP
IMAP4
EMS
Data Formats
J2ME
WAP 2.0
HTML
XHTML
MIDP2
Dimensions
Width
2.1 in.
Height
4.28 in.
Depth
0.86 in.
Weight
4.37 oz.
Miscellaneous
Exterior Color
Black
Pink
Included Accessories
Travel Charger
User Manual
Headset
Software CD
Arm Strap
Family Line
Nokia N
Product ID
32599097
On the main screen type
*#06# for checking the IMEI (International Mobile Equipment
Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# – Display the MAC address of the WLAN adapter. This is
available only in the newer devices that
support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# – takes you to a secret menu where you may find some of
the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair – if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# – Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
#3370 – (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# – Half Rate Codec activation.
#4720 – Half Rate Codec deactivation. The phone will automatically
restart
If you forgot wallet code for Nokia S60 phone, use this code reset:
*#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the
lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin#
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
