Question about Dell OptiPlex GX270 PC Desktop
My dell monitor cant display 32bit colour. by ageni
Posted by lordcobbina on
Anonymous
  • 77 Answers
May be your graphic card don't support 32 bits
try other cards
Posted on Sep 14, 2009
Dell Display problem
Control panel not sure of Computer but look for display find colour button to alter from 256 to true colour.
Jan 28, 2013 | Dell Computers & Internet
I a having a laptop-HP pavillion dv6000,RAM 1gb and OS-32bit with window 7 ultimate,a problem of colourisation.i mean the display colour has change like a spray a of colours(green,deep blue)on the normal...
Try plugging in an external monitor and see how the display shows on it. If the display is ok on the external then your LCD Screen is going bad. If it shows the same colors on the external monitor then your video graphics card has issues.
Apr 21, 2012 | HP Computers & Internet
Dear sir moniter colour change and very bor full display plz help
hi,
There is some dry soldering in the base board of you monitor. Its simple problem but the user cant rectify it. because removing the base board is not much easer. so consult some electronic repairing shop near you. It will not cost a lot. if you can do the same the i can assist you to do the same. feel free to contact me through fixya.
ok
Feb 10, 2011 | Dell M570 15" CRT Monitor
Can't drive monitor
Try moving the monitor down to a lower res. I would try 640 x 480 first and then go up from there. Also, some adustments may be required in displays for the second monitor....
Mar 07, 2009 | Acer Aspire 2930-4661 Notebook
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Can you help me to fix my monitor?
Check the connector of the Pc sometimes if don't put it right make those simptoms.Good luck
Jun 03, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Need help about screen resoulution....
Try out these simple steps
1. download latest graphic drivers of your graphic card
2. orchange your monitor refresh rate to minimum like 60 HZ
Mar 03, 2008 | Iolo Technologies System Mechanic 5...
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Dell OptiPlex GX270 PC Desktop Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
