Question about Ricoh Computers & Internet
Ricoh is not printing jpg or png files - Ricoh Computers & Internet
Posted by Shmill Shmill on
5 Related Answers
KenKaBob
KenKaBob
  • 89 Answers
SOURCE: Problem getting the Ricoh Aficio CL12000N Printer to print files
Hi, Sorry you are having problems,
Ok, well, that sounds to me like you have a new version of Adobe Acrobat. And, well, the new version of Acrobat works with more and more options and bigger and more complex documents.... And.... well, your G3 and the Ricoh printer just can't handle these files.
So, what is the solution other than buying a new computer and a new printer, which would certainly solve your problem, ?
What I recommend is print pdf files as images, you will find this option in the print dialogue box, unfortunately, i don't have access to a Mac OS 9 machine to take snapshots to show you, but, if you snoop around the print dialogue options, I'm sure you'll find ( Print as Image ) and that feature really reduces the weight of the image you are sending to the printer.
Posted on Apr 02, 2009
pifonski
  • 142 Answers
SOURCE: My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
Posted on Mar 02, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: How to operate the cx6000
http://majorgeeks.com/download.php?det=5622
Sumatra PDF is a slim, free, open-source PDF viewer for Windows. It's designed for portable use: it's just one file with no external dependencies so you can easily run it from external USB drive
Sumatra PDF Portable enables you to read and modify any PDF according to your demands. This tool is the lightweight Sumatra PDF packaged as a portable app, so you can view PDF files on the go. You can place it on your USB flash drive, iPod, portable hard drive or a CD and use it on any computer, without leaving any personal information behind.
Sumatra PDF is a slim, free, open-source PDF viewer for Windows. Sumatra has a minimalistic design. It
Posted on Mar 14, 2011
matt_g_walke
Matt Walker
  • 62 Answers
SOURCE: it will only print as picture, not as a document or pdf file
Cindee,
To be able to scan in as PDF, you'll need a software that is capable of creating PDF's from scanned images.
Adobe Acrobat is the top software for this, but it's also expensive. Another popular software is called ScanToPDF. It's less expensive than Acrobat; it also has less features.
Once you have a software installed on your computer that has the ability to create PDFs, then you should be able to scan a document and save it as a PDF.
Good Luck! Hope this helped!
Posted on Nov 17, 2011
Apoorv S
  • 240 Answers
SOURCE: Microsoft picture it premium 10 will not save jpg files. It saves in every other format fine. Can you help?
no issue..open it with paint nd save it in any format u want
Posted on Aug 23, 2012
How to attach photos to an email
Click on the paper clip icon an it will direct you to your pics
Aug 29, 2017 | Computers & Internet
How to take a screen shot on an asus pc laptop
sir find the (print Screen - Sys Rq) on ur keyboard.. after you click it..
go to paint and do this comman (ctrl+v) .. then save it to your comp.. dont forget to choose what file do you like jpeg,gif,icon,png
jpeg or jpg are mostly recommended..
Aug 26, 2015 | ASUS Computers & Internet
In the middle of the page there is no printno color, nothing, only right and left it works !!!???Thanks to every Helper out there !
dont print pdf files,convert them or turn them into a png file,use the snipping tool,it is like doing a screen shot but more controllable
May 25, 2015 | Ricoh Aficio™ CL3500N Laser Printer
Canon mx410 how to scan multiple pages into one document
What you need to do is select the file type as .png instead of the default .jpg. A .png file will create one file with multiple pages.
Good Luck
Mark
Aug 31, 2014 | Canon Pixma MX410 All-In-One Printer
Word docs sent as email attachments are arriving in my inbox as png files - useless. How do I change this please
.PNG stands for "Portable Network Graphics". Sounds like the sender may have scanned the document, and sent the scanned document to you? Scans will come out as either .png, .jpg, or .pdf formats.
If the file is a .png, you won't be able to edit in MS Word.
Another thing to check - Make sure when you are working on a Word Document, you are saving it as a .doc file.
  • Open MS Word Document
  • Do your editing
  • Click on the "Fille" button, and then select "save as" option
  • In the window that appears, next to the "save as type" wording click on the down triangle to see different formats to save. Select ".doc"
Bottom line... tell whomever is sending the emails with attachments, to send you the MS Word file, not a scanned file.
Jul 26, 2014 | Dell Inspiron Computers & Internet
Memory overflow
try printing a different file format. is teh printer connmected via network or USB? connect either way and see
Apr 09, 2013 | Oki Brand Oki 62435103 C330dn Laser...
pifonski
Feb 24, 2011 | Ricoh Aficio SP C820DN Laser Printer
Ocr
Use any OCR software and it will take care of converting the scanned image into .DOC file or .PDF file. Some OCR softwares require a minimum dpi output, standard being 300 dpi. Ensure that the image is clean and 'straight', deskew if skewed.
Feb 19, 2008 | Canon CanoScan N650U Flatbed Scanner
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Jun 14, 2007 | BenQ 5000U Scan to Web Scanner
Open Questions:
RICOH PRINTER tEcH SupPoRt pHoNe nUmBeR#@1-800246-7609 VIKI USA RICOH PRINTER Tech Support Number +1-800246-7609 to resolve all RICOH products. RICOHis an American multinational company which was founded by Michael RICOH using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, RICOHPRINTER support number, and selling of computer-related services and products.RICOH PRINTERTechSupport Phone Number Recently, RICOH has been named the number RICOH PRINTER technical supportadvice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, RICOH PRINTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Secrvice Requests, Chat, and Phone .Contact RICOH PRINTER Support for Setup & Installation RICOH PRINTER Wireless Setup Support & Installation RICOH PRINTER Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for RICOH PRINTER Connect, you'll be searching out RICOH PRINTER Connect setup as well. So, here we're with all the setup process and recommendation for your to RICOHPRINTER Connect. Get RICOH PRINTER Setup Instant Support Phone Number and Customer Services. RICOH is a US-based multinational techorganization having its headquarters located in Round Rock, Texas.This tech organization supports, repairs, sells, and develops technology products.
Jul 17, 2019 | Ricoh Computers & Internet
Computers & Internet Logo
100 people viewed this question
Top Ricoh Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
