Have palsonic pt5525su tv cant bring up tv guide
Posted by Margaret Herrick on
I have a one for all remote for a tv i need a coad for a palsonic tv
https://www.eliztech.com/remotes/pilot/pcodes.php?brand=palsonic
Jul 25, 2018 | One For All Televison & Video
Code for a pdp4225hd
http://tv.manualsonline.com/manuals/mfg/palsonic/pdp4225hd.html
Free manual - see if contact information is available for the manufacturer of the
Palsonic PDP4225HD Flat Panel Television
Apr 22, 2018 | Televison & Video
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
When I try to retune TV to pick up new TV stations I get sound OK but a black screen with message invalid format.
Check stations MPEG format . Check if it is MPEG4 and check if TV can decode MPEG4 . A firmware update may be available on tv and may fix it but it has the risk of turning the tv into a brick if something goes wrong during a firmware update.
suggest contacting palsonic to see if firmware possible and which one to use.
http://www.palsonic.com.au/customer_service/upgrade/default.htm
Feb 23, 2016 | Televison & Video
Need a remote for a PALSONIC 32'LCD TV Model no PLCD32HD Thanks
Universal remote control setup codes to Palsonic brand TVs are 028,019,092,082,045. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 07, 2013 | Televison & Video
Can't get rid of electronic program guide on screen of palsonic tftv8060mw it appears on screen automatically after 1 minute and won't go away! EPG button on remote does nothing
Go into the TV background Menu options and search out the program guide settings that should be there. Turn off the "always on" setting.
Dec 26, 2012 | Televison & Video
I have a Palsonic tv and it keeps turning off ,what could be the problems
There might be some loose solder terminals at its main power regulator board.
Dec 01, 2012 | Televison & Video
A Universal remote which will work on a PALSONIC television?
It will be very difficult to get a sutable universal remote for this set. You can try. That's all.
May 10, 2012 | Televison & Video
I have a Palsonic 6568pft TV model and my remot at
i need more information with respect your tv or device, because in internet i dont know look your model of tv
Mar 07, 2010 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
