SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
SOURCE: Looking for a manual for a Pfaff 463 industrial
Well you may follow the link below to get the manual -
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Pfaff_Industrial.htm
Good Luck!!
Thanks for using FixYa!!
Posted on Mar 27, 2011
SOURCE: how do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Posted on Sep 22, 2012
SOURCE: where do i get a needle clamp for a pfaff 463
Many vendors in the states. Dunlap Sunbrand and Atlanta Attachment are a couple.
Posted on Apr 17, 2015
