Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Prints nothing on paper. checked ink cartridges
Prints nothing on paper. checked ink cartridges and there new. ran the cleaning program and still nothing prints on paper or photo paper. completly blank. I had this happen a couple of months ago. Kodak sent me a new ink cartridge bar. Now the same problem is happening. please help. Tired of when it works it does great detail work, but when it doesn't print then normally I'm out of a printer for a week. Please help.
    Sergeant:
  • 191 Answers
Please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Posted on Sep 14, 2009
  • Lynn Bowersox Sep 07, 2013
    This does not work. The printer will not even copy.
6ya staff
SOURCE:
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Make sure you are inserting genuine Lexmark cartridges.
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
After cleaning printer heads no ink is printed
If its an EPSON yes! There may be other brands that do it as well You needed to mention the brand and model which did not appear in the question
Aug 17, 2009 | Office Equipment & Supplies
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Won't print PRIXMA iP1500 Going through the actions of printing but no ink appear on paper. Deep cleaning done, reset done, new cartridge done, alignment printing done, still no ink.. and it did print a...
If using aftermarket inks you sometimes have to rap them on a paper towel to break an air lock.If you see ink coming out after rapping them try to print again.If nothing comes out you may have a bad print head or purge pump.
Try cleaning the head (without cartridges)in a 10-20% ammonia warm water mixture for 30-45 min.
Completely dry the head before returning it to printer.
Jun 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon MP760 black ink dull and has stripes
Take the cartridges out and also the printhead and set the nozzle of the printhead on a 5-sheet pile of kitchen paper that was make wet in the middle with some lukewarm demineralized water ( water for an iron )there is not much necessary if there are clogged nozzles deep inside the printhead buy cartridge flush different methode for printers to find
How To EASILY Unclog Ink Jet Print Heads
Aug 26, 2017 | Canon PIXMA MP760 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
292 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
