D-Link DI 514 Wireless Router (DI-514) Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I use a dl 514 router. the computer shows a wireless connection and a strong signal but i'm not able to get online. now that I'm using a cable, it still shows a wireless connection with a strong signal.
  • 1 more comment
  • dwelch01 Sep 14, 2009
    I assume that it has because the router has worked in the past and just started doing this today. Thanks
    I assume that it has been configured because it has worked for several years and just started doing this today.
  • Anonymous May 11, 2010
    Has the wireless card been configured with the router's wireless settings (eg SSID and encryption etc)?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
Helped
88452
Points
729
Its quite likely that the router is not connected to your computer wirelessly. Which means, your wireless card is not picking up a IP address. I would suggest two thigns 1. In your wireless utlity , try to repair the connection. 2. Check if you have a static IP address. If you do, remove it.
Hope this helps
Thanks Ranjit
Getting wireless internet from the router. i got
The setup a wireless connection and secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
2answers
My wireless network doesn't have a strong signal
mcdevito75 here, Your wireless as all wireless depnds on Satalight position, depending on where you live, the signal could be weak at times. Just as your signing on to connect your wireless to the internet, click on up-dates. You can also contact your wireless provider (maker of your wireless) for additional info. Hope this helps.
Can't find any Dl-514 files that aren't DFL. Borrowed the Dl-514 but forgot to ask if he had a installation cd.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
2answers
Cannot seem to get ip address when trying to connect to wireless network
check if the computer has the DNS service started, check if the lan connection is enable.
Dl-514 d'link can't read signal from macbook
Perhaps the reason it has been sitting around at work for some time is that someone just didn't have the heart to throw it away after it went afoul?
Try resetting the thing by removing power, pressing in the little reset button on the back, holding that button in whilst re-applying power. Hold it in for 30 seconds after you plug it back in. That should cause the unit to reset.
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
X box 360
You can't get an IP address on the Xbox that way. You need to get an IP address from a device that works as a DHCP server such as a residential router. Connecting the Xbox to the PC will do nothing for you.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
