You check PalmOne for possible OS updates and patches. Some Palms do have issues with some cards.
Palm OS ver 2.0? So, you have a palm pilot pro or similar? Please clarify because these were one of the first palm which had no sd expansion.
Is this a Treo? Can you read the SD card on the computer, but not on the phone?
You may have to format on the phone. Give me a little for detail and I'll try to help you out.
Best Regards,
Bill
First delete all temporary files and cookies from browser.
Then first uninstall card driver then reinstall.
Aslo check yoour usb ports are working fine and check 1 by 1 usb ports.
Also reset factory defaults settings in Palm then check.
Let me know if you need more assistanse.
Thanks.
You can run a repair of the OS.
That should fix the issue.
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
Thanks
Smith
hI,
If your card is sdhc it will not work the device is only natively capable of reading normal sd cards.
The only suggestion I can offer is to open the install tool, then on the device go into the hotsync application on the Centro. Both should be displaying a user name. If the user name on the device doesn't match the one in the install tool, click on the drop down (On the install tool) and change it to the correct user.
Yes you may have to contact the software venders and re-register the software.
Thanks
Smith.
repair which OS? The desktop or the Palm OS?
I am using a laptop running Vista not XP.
the previous "expert" doesn't have a clue what she is talking about. My Palm Lifedrive does recognize my memory expansion card while used within the confines of the device, but if I use my web browser, go to a web site perhaps to download an ebook, I can't download it to the device for the error message tells me there is not enough memory. I can't download it to the memory card for it does not even recognize there is a memory card available. I need to get the Palm Lifedrive to recognize the memory card while on the internet so I can download to it.
The problem is within the Palm Lifedrive itself. The steps you just gave to me is performed on my laptop. First, which browser temp files do you want me to delete? On the laptop? Which card driver? On the laptop? I do not have another or different card driver for the Palm to install. Please be clear on your instructions. Thank you.
I know you guys are trying but you don't have a clue what the problem or the answer is. I have done all of your suggestions plus many others. I am ahead of you on all of these. I don't think you will be able to help me. This is my last communication with you. Thanks....Mark
