Question about Samsung Office Equipment & Supplies
After win 10 update Samsung scanner not working - any suggestions ?
Printer work fine only scanner not working says scanner not connected
Posted by Peet BOTES on
Jim Waqabaca
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
The latest driver for your scanner needs to be installed on your PC.
Posted on Sep 14, 2020
5 Related Answers
bandana_gyrl
Sarah McDonald
  • 181 Answers
SOURCE: scanner won't work but the printer does
Ok here is the answer you have all been waiting for - look on the CD that came with any HP printer for the mac and you will see that it is for 10.3.9 and 10.4. I bet you dollars to donuts you have the new 10.5 leopard software and you got the new printer for free from the apple store.
All is not lost - go to the hp website at www.hp.com and on the left side you will see a grey menu that says software and driver downloads click on it and type your product. The version right now is 9.7.1 once you get all the way through. DO NOT INSTALL THE HP INSTALLER FILE - it is the same as the CD.
Well on the off chance your using windows the same applies - delete the old software on your computer and follow the steps above. The version number you will need depends on what OS but just make sure it is the most recent and you should be fine.
Posted on Feb 28, 2008
old marine
old marine
  • 2318 Answers
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
Adam Peake
  • 421 Answers
SOURCE: cannot communicate with scanner message
Try an get a USB 2.0 printer cable. Some of the Canon scanners will not communicate quick enough without one.
Posted on Nov 08, 2008
Anonymous
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan  on IMac with Epson Stylus CX3900?
Posted on May 15, 2009
SOURCE: the network printer will print a test page but nothing else
You need to connect to this printer with a Win 7 Driver installed on the Win 7 machine, and when you finish that, install. Then Go to printers>>ADD PRINTER. When the menu comes up, select, Connect to a NETWORKED Printer, basically navigate to the printer and select. Now Before you can do that,you MUST, be on the Same Workgroup, Must Have a Login Password, Must Have a PC Name. On the Printer, on XP. Sharing MUST be enabled on Printer, also there MUST be a Printer NAME too. After you have st all that up, do as I initially said, install the Win 7 driver, find printer, login, and you'll be printing in no time.
www.microsoft.com/windowsxp/.../networking/.../honeycutt_july2.mspx How to link above, below is a troubleshooting link.
support.microsoft.com/kb/308007
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=uk&os=228&product=1153481
Above Drivers for printer GET ALL scan manger too Get FULL Version and install.
Posted on Apr 14, 2010
How to add my printer HP3058A to my laptop
go to control pannel
add device
search for your device or connect you device
Mar 17, 2016 | HP Office Equipment & Supplies
Headphones choppy audio when connected to Samsung laptop after updating to Windows 10. Ideas?
That kind of problem is related to wrong drivers on the Win 10. Visit Plantronics site and download last drivers specifically for Win 10 and your device.
Aug 23, 2015 | Plantronics, Inc. Plantronics BackBeat Fit...
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
I have MP250 all in one I installed the drivers on windows 7 the printer and copier are working well but when I scan a paper the following error appears [ can't communicate with scanner cable may be...
More recently Canon updated drivers and firmware for printers. With the modernization of Windows OS to Win 10 (2017-18) all reference code is now Win 10 and not always backward compatible. You would be best served to update the operating system, update the printer drivers and firmware. Once you do this, everything will speed up, go smoothly, and you will be more secure.
Jan 12, 2018 | Canon Office Equipment & Supplies
HP Scanjet 4850 worked fine until I replaced the OS with XP SP3
win xp is 10 years out of date so you have lost the driver for the printer by the upgrade
If you go to the hp web site there may be still a down load for your model printer that is compatible to win xp
if so select that and down load it
run the down load when asked
AS win xp , win 7 are both out of date and no longer supported by Microsoft you should consider installing win 10
Feb 08, 2018 | HP ScanJet 5100C Flatbed Scanner
Printing prob while adding printer on sharing basis
Hai
I have a SAMSUNG SCX-4100 Printer which is not working even though printer is installed to the system the message is appears as " WINDOWS CANNT CONNECT TO PRINTER, THE LOCAL PRINT SPOOLER SERVICE IS NOT RUNNING. PLEASE RESTART THE SPOOLER OR RESTART THE MACHIN. Please suggest in this regards.
Neelesh Agarwal
May 28, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Scanner not working
Samsung can be cheeky with support i have found and not as helpful with tech help. Instead of going off in tiny circles with unlocking etc, i would go for the quick fix and suggest your scanner may not have installed properly when you installed it. As you have installed the drivers again with no luck i would even suggest goint to samsung web site and downloading new updated drivers for your printer to eliminate corrupt drivers. Does you pc register the scanner being there? Go to control panel, hardware/ printers, find your printer and check all the drivers and whether scanner is actually present on the pc here.
Aug 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
