Nextbook7p12-8 does not start ~ Stalls at first opening screen with lincoln quote reset on program after vol and start button reset does not fix. Maybe reload firmware ? But not sure how With
Posted by Tablettestbank on
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: My Creative ZEN 8 GB has Firmware Problems
Try uninstalling Windows Media Player version 11 from your computer before trying to reload the firmware. It works wonders.
Posted on Sep 16, 2008
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: "I had the exact same
Please get the compatible driver here :
www.driverskit.com/MP3.html
www.nodevice.com/driver/category/MP3_Player.html
www.freedownloadscenter.com/Best/free-mp3-driver.html
www.driverslab.com/drivers/MP3/iRiver/15/56.html
www.samsung.com/us/support/downloads
Warm regards, Jay__90Jh7
Posted on Feb 26, 2011
John Bishop
  • 368 Answers
SOURCE: I have lost control. Hit the reset button inside
From the information given it sounds like it needs to be replaced. On the other hand, a more educated guess might be obtained with a call to the Jandy technical support line at 800-822-7933. They should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Posted on Aug 28, 2011
Amanda Verdoorn
SOURCE: I have a LG BD390
Do you figure out a way to fix this problem? I'm wondering because mine started doing this today. All I can do is open and close the the tray and if I hold the power bottom for a few seconds it will turn off. Thank you. Amanda
Posted on Nov 18, 2011
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Apr 12, 2015 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
Tip
Fix Windows 8 Error 10
The TIPS this article will help you get detailed diagnostic information and fix the error 10 in Windows 8 operating system.
Update Malfunctioning Drivers
Update the drivers for malfunctioning devices indicated with a yellow color exclamation mark.
gDz7TRY2sKy0361Sog6d_QRTmWz6S9-nl9X3yA0HIer5Haj_GQ5bV5l4qGjSNXSfX4ooWo_pbQ6262sUBB851TJtcW-Pgq_lfLjbzlCXBboCmW3twhWYyUDEwcIg" width="560px;" height="671px;" alt="Charms-Bar.png">
1. Press Windows Key + C.
2. The Charms Bar will be displayed.
3. Click the Settings icon.
4. Click Control Panel.
5. Click System and Security ' Administrative Tools.
6. Double click Computer Management.
7. After Computer Management dialog opens, expand the top root node, i.e. Computer Management (Local).
8. Expand System Tools node. Select Device Manager.
9. Yellow colored exclamation mark will be displayed to malfunctioning devices. Right click a device and select "Update driver software".
10. Follow the on-screen instructions.
Reset Internet Explorer Settings
Set the default browser settings.
6QpjEtDk8qJZs2mphJj-3-XktdOeYcnxtYFj11QQB9Xqb-p3l-thAWDgoVOpbENPhFwNwUnj-6qwJLTcXdFxvBp2jD4bP8Qxz5dblvcliY5Di5F8-Ju8sgiPg8xw" width="624px;" height="376px;" alt="Reset-Internet-Explorer-Settings.png">
1. Press Windows Key + X.
2. Select Command Prompt (Admin).
3. Type "inetcpl.cpl"
4. Press ENTER.
5. Internet Properties dialog will open.
6. Click the "Reset" button and confirm the action.
Change the Security Zone Settings
Go to the Security Zone settings and set appropriate levels for the Internet, Local Intranet, Trusted Sites and Restricted Sites zones.
AawqQhUftQ2Jr4EB1hN7dlsse5wSRe6YYQg1V7o0y6pPCnq1_hqiYQuJHHh7OcLoIV9ZopXEJfL3ieBFbaKIZhUP2I7N056B1fStHbuuudMooR6Vp9Jf0IigkTWg" width="423px;" height="542px;" alt="Internet-Options.png">
1. Open Internet Options dialog. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
2. Click the Security tab.
3. Select "Internet" icon.
4. Move the "Security level for this zone" slidebar to Medium-High.
5. Click "Local Intranet" icon.
6. Set Medium-Low level for this zone as in the Step # 4.
7. Click Trusted Sites icon.
8. Set Medium level as in the Step # 4.
9. Click Restricted Sites zone and set High level for this zone as in the Step # 4.
10. Click Apply, and then OK.
Delete the Browsing History
Every time that you open Internet Explorer corrupt history is loaded. Delete the browser history to fix Windows 8 error 10.
XDtvYecmugRcsb198KaB0YszDRSi1mGcxY-wpowd_jfyYmqawXrtuuTFZH54IAsNi0v4UUW-2gJD_U9ytRKvDgAemkWIOA25IhmJckjLYMKwZF79ooH8bblZQfOw" width="624px;" height="332px;" alt="Delete-Browsing-History.png">
1. Open Internet Explorer.
2. Press the Alt key of your menu bar.
3. Select Tools ' Delete browsing history.
4. In the new dialog check-up all the checkboxes displayed.
5. Click the Delete button to start cleaning the Internet history.
Disable the Smooth Scrolling
Smooth scrolling feature may not work properly due to graphics issues. Disable the smooth scrolling feature to prevent this problem.
2. Click the Advanced tab.
3. Scroll down the scrollbar. Under Browsing category uncheck the "Use smooth scrolling" checkbox.
4. Click Apply ' OK.
5. Exit and re-open the Internet Explorer.
Turn Off Hardware Acceleration
Many applications use the hardware acceleration feature. Disable the hardware acceleration and check whether it helps.
qBTFDPo49_raes7y1knOMykZeW33CJRJ7QDmYryXT2oBZ3ZyVLy4pZPxgWA5L2yDsPwSbFizWYppPUn2MNFY-OLGuLnWimun1HJmmBjRP7s3RnzyBFnkKyevZadA" width="624px;" height="435px;" alt="Display-Settings.png">
2. Select Search option.
3. Type "desk.cpl" in the Search Box.
4. Click the Apps icon and open it from the Search Results.
5. Screen Resolution dialog will open. Click the "Advanced settings" link.
6. In the subsequent dialog click the Troubleshoot tab. If that tab does not exist it means your graphics card does not support the hardware acceleration feature.
7. Set Hardware Acceleration= None
8. Click OK ' OK.
Reregister Problematic DLL
Reregister the system file named rasppoe.sys using Command Prompt.
k_C1fljiI30RqbQr0RcDaLI67Bnrxyc-t2BAynOldOVABPjSCHobXaDc9h4wPhKwG41xuthC1yEtgpkeE1mYd4z5GscwbRq8KvN_bm07yrrMJt8RTD8v87VsgLsw" width="624px;" height="316px;" alt="Register-DLLs.png">
1. Press Windows Key.
2. Type "CMD" in the Search Box.
3. Click the Apps icon.
4. Right click the "Command Prompt" icon in the Search Results page.
5. Click the "Run as administrator" icon at the bottom of the page.
6. Type the following command:
Regsvr32 rasppoe.sys
7. Press the ENTER key.
Rename Problematic DLL
If there is any problem with the rasppoe.sys it will be resolved after renaming the file.
1. Double click Computer desktop icon.2
2. Open the following location:
C:\Windows\System32\Drivers
3. Rename "rasppoe.sys" as "rasppoe.sys.old"
4. Restart your computer.
Turn Off the Software Rendering
If the software rendering feature is not supported, simply disable it.
1. Open Internet Explorer dialog box. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
3. Uncheck the checkbox named "Use software rendering instead of GPU rendering" under "Accelerated Graphics" category.
Change NVIDIA Graphics Settings
Go to the NVIDIA Graphics Settings and uncheck the Stereoscopia 3D setting.
Reinstall Flash, Java & Silverlight
Uninstall and reinstall these three programs to check whether program files corruption was an issue or not.
ueHytD4giGWOXrR_3IWKFfhwbQ9jzLmwUo4vkrzaGnQ4codvWpaKLAD2mWNh7vMHYdPxG-1cgfa91Bj_oMXCyeJ65-x4gMobvJBCNBR6fFp7rDxkurxoAbK5nahQ" width="624px;" height="435px;" alt="Programs-and-Features.png">
2. The Start Screen will open.
3. In the Start Screen type "Uninstall a program" in the Search Box.
4. Click the Settings icon.
5. Open it from the Search Results.
6. Right click a program name and select Uninstall option. Uninstall the Flash, Java and Microsoft Silverlight.
7. Download the above programs from the Internet.
Change the Environmental Settings
Change the values of Environmental Settings in order to fix Windows 8 error 10.
8yve5KFc4UjrHg0s4dJHlHctnOeiBs9cI9FSVHoa0nsfecop4N8kbc2ccl8bOHdcsetF6ZIhLA3L_WGSsmOnR6gM4rolUg8o5-YeAfTEMMSXhOBjT8nWUqBR0XpQ" width="397px;" height="439px;" alt="Environment-Settings.png">
1. Right click Computer desktop icon.
2. Select Properties from the context menu.
3. Click "Advanced system settings" link.
4. System Properties dialog will open.
5. Click the Advanced tab.
6. Click Environment Variables button.
7. Under "User variables for " category two temporary folders will be displayed.
8. Select the "TEMP" folder.
9. Click the Edit button.
10. Specify Variable Value: "C:\Tmp" (without quotes).
11. Click OK ' OK ' OK.
Fix Issues in Registry
Often errors in Windows registry result in such problems. It is wise to keep Registry cleaned from corrupted entries. To fix Windows 8 registry, use the Intel Software Partner Reginout System Utilities here: RegInOut System Utilities
on Nov 24, 2014 | Microsoft Computers & Internet
My home screen and reset
Hi, unfortunately its a job for a technician, yr fone has to be connected to a computor to access the security setting. Its a quick job provided you have tornado cables. Take it to yr nearest trusted cellular shop.
Dec 02, 2014 | Kurio Touch 4S Handheld
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Jan 11, 2014 | Nextbook Premium 8 Se Android
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
My boost mobile galaxy rush just decided to stay stuck on the start up screen and even removing the battery sevrra after its been like that for two days straight. Now i can go to the hard reset and...
You may need to factory reset your device. (Erase all data and restore the operating system to stock). Most devices you can accomplish this by powering the device off. Tap the power, then immediately press and hold either (power + vol down) or (power + vol up) until you get a menu. Use the vol buttons to navigate to factory reset or recover and the power button to select the option. If neither of these work you may need to consult the manufacturers site for factory reset instructions.
Nov 23, 2013 | Cell Phones
My samsung omnia 7 shows only the welcome screen. i am from the philippines and my phone was given to me by my boss who lives in australia. it opened once but after the battery was drained, i recharged it...
Try to update the firmware ..
Tools: Samsung I8700 Download Program , USB cable ,USB Drivers.
1.Samsung Omnia 7 usb drivers >I8700_USB_Drivers.rar.html
2.Guide: How To Update Samsung I8700 Omnia 7 Firmware +Download program > http://www.mediafire.com/?m70ic2gj75wyuke
3.Samsung I8700 Omnia 7 Firmware >file/Xf3UGPX/I8700_XXJK1.rar
Follow the instructions from the downloaded guide on how to update the firmware. To enter download mode: Press and hold: VOL UP + CAMERA + POWER (Let go of POWER button when device turns on while keeping other 2 buttons pressed) When you see the 'Samsung Omnia 7' startup screen, count 5 seconds then let go of VOL UP + CAMERA.
Aug 21, 2011 | Samsung Omnia 7 (8 GB) Smartphone
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
