Question about NordicTrack Exercise & Fitness
NordicTrack Model T 6.1 Treadmill I get an Error Code FF when I insert the key. Help and THank you Arthur
Posted by Arthur Costonis on
5 Related Answers
lilytoy
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
Anonymous
  • 64 Answers
SOURCE: nordictrack treadmill will not close
Check elevation position.
Posted on Jun 08, 2009
vpaaf
Howard
  • 115 Answers
SOURCE: When I turn on the treadmill and insert the key FF
what type of treadmill is it
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on Oct 10, 2009
Anonymous
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
Posted on Nov 13, 2009
Anonymous
  • 218 Answers
SOURCE: My Pro-Form 575 shows code FF when powered up
console is bad and needs replaced
Posted on Aug 12, 2010
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
Do all C1800s NordicTrack treadmill models use a safety key to turn on ?
The answer is yes you need a key. You also seriously need to read the manual before you use this machine.
https://www.manualowl.com/m/NordicTrack/C-1800s/Manual/341906
and this one for why and what could possibly go wrong - for your entertainment.
https://www.youtube.com/watch?v=qNPhVVjnoC0
Jan 29, 2015 | Nordic Track NordicTrack C 1800 Treadmill...
As soon as my treadmill is powered on I get an error code of dC-6, and it won't function, how can I fix this?
Hallo,
Fisrt of all, i hode like to thank you for you kindness.
I have more details of the machine.
Marc: GREEN MASTER
Model: 928
i Hope that can help you.
Thanks again
Sincerely
Carlos Silva
Feb 14, 2014 | Lifespan Fitness Treadmill Walking Belt...
NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
Image treadmill 17.5s error code FF
Dear Sir:
Since your equipment had been stoped by aprox 6 months.
I will recommend 1) lubrication between deck vs walk belt very important.
2) RUN the calibration software, this special design for to diagnose and troubleshooting the machine, is under Hood( see the instruction).
sincerely. God bless you.
attached: is my design for block diagram for treadmill for too diagnose and troubleshooting.
ernesto a cuadra
managua, nicaragua. c.a.
Jan 06, 2012 | Icon Image 17.5 S Treadmill
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
I have a Nordictrack exp 1000x and it won't turn on. Any ideas?
Right next to the power cord is a circuit breaker. Check it to be sure it has not tripped. If so, reset the breaker.
Check the outlet, be sure there is power.
If that checks out, remove the motor cover (unplug the machine from power first) and check the fuse on the controller board. Chances are if the fuse is blown, the controller might be defective. Replace the fuse and try the machine. If it blows again, the controller is defective..
Dec 17, 2010 | Nordic Track NordicTrack Treadmill, A2550
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Exercise & Fitness Logo
135 people viewed this question
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
