Question about Refrigerators
Rs21 samsung twin cooling
Samsung twin cooling RS21 model...well the frigde side of it has stopped cooling altho light working and the panel lights flashing at temp. freezer working fine...any ideas what is wrong n how to fix?
Posted by blue_nosed_n on
Syzys
    Sergeant:
  • 361 Answers
It's quite possible that your defrost timer is faulty, and needs to be replaced. But I suggest you don't just take my word for it and instead thoroughly check out the user manual first, before potentially bringing in a repairman:
Samsung RS21 manual
Posted on Dec 07, 2014
Anonymous
  • 65 Answers
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Posted on Sep 14, 2009
I HAVE A RS21 REFRIDGE IT IS DEFROSTING DISPLAY IS ROLLING
You need to make clear with your thermostat sensor.
Jul 14, 2014 | Samsung Refrigerators
Tip
Samsung fridgefreezer troubleshooting
hello and thanks for checking out my samsung fridgefreezer trouble shooting section ..<br /> <br /> most of the appliance,s i deal with are made for europe but they seem to be sold worldwide under a different model - so hopefully the info i can give out will apply to most models ? ..<br /> <br /> probally the best way for you to find out about common problems on samsung fridge freezers is to have a look at some of these videos on youtube ..<br /> <br /> samsung fridgefreezer channel /...<br /> <br /><utube src="RP9XLji-gdw"><br /><br />rsh1 model video below<br /> <br /><utube src="wLFcmJEGJMs">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 model video below <br /> <br /><utube src="7xEBoJRBD5Y">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 ice maker fault video below <br /> <br /><utube src="R-va_Siu3zw"><br /> feedback for customer who have received help <br /> <br /><utube src="TGIrwv3xkWg"><br /> hope these videos are able to shed some light on whats causing your samsung fridgefreezer problem..
on Dec 02, 2010 | Refrigerators
Service manual rs21 dcns
go to their website
WWW.
Samsung.com
refrigerator
May 21, 2014 | Samsung Refrigerators
Where is the water bottle in samsung rs21?
For a schematic of the refrigerator, including the location of each part, refer to the user manual:
Samsung RS21 manual
Dec 23, 2013 | Samsung Refrigerators
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung side by side fridge/ freezer model number RS21NGRS . Fridge side is not cooling . The fan was making a noise and has now stopped but the temp light is flashing how do i sort this problem thans.
Hi, there is a known fault with the Samsung RS21 units. If you unit is less than 5 years in luck, it is covered by the Extended warranty they have put in place. Apparantly this was featured on BBC watchdog!. i've had the same problem and had it fixed free of charge by Samung. Either raise a service request on the Samsung uk web site, www.samung.com/uk or call the customer services on 0845 7267864 and explain you description. the noise is an ice build up which stops the internal fan pushing cold air around the fridge. the bootom of the fridge , in the drawers is cold?
Aug 12, 2009 | Refrigerators
I have a samsung RS21DGRS and it keeps makung a wurring noise from inside rear of the fridge compartment and now the water dispenser has stopped working .
very common issue on samsung rs21 models ,
repair kits have been available for a few years now
this video may help
how to dismantle samsung rs21
Sep 05, 2008 | Refrigerators
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Refrigerators Logo
1,293 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
