Question about LG Televison & Video
I have an LG tv roughly nine years old, model is 32LD520-UA. The picture is fine, but the tv will cycle/power on and then off periodically, regardless of whether streaming or watching satellite tv.
Not sure what the issue is and if worth trying to fix. Not a very expensive TV.
Posted by Chad Mirabile on
Tom Chichester
    Top Expert:
  • LG Master
  • 55,960 Answers
The power supply is failing.
Posted on Sep 10, 2019
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: green vertical lines
Possibly needs a new control circuit board or lcd panel
Posted on Jul 25, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: LG projection TV model 52SZ8D-UA sound go on and off
your audio board is going out take it to a shop and have it fixed
Posted on Dec 07, 2008
Anthony Gonzales
  • 267 Answers
SOURCE: I have a two year old high def LG Plasma TV Model 42PC3D. Have so
You probaly have a bad y or z sustain board
Posted on Jun 26, 2009
Andrew White
  • 41 Answers
SOURCE: LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Posted on Mar 13, 2010
Anonymous
SOURCE: MY LG LCD TV PICTURE DIED
I have a 47LG50 with the same problem watching like normal and then all I had was sound with a faint light in the background no menu or anything. could hear channels change when using the remote. similar problem for me? what is the cost of something like this?
Posted on May 27, 2010
Tv has no picture
Power supply issue.
Sep 03, 2017 | Vizio Televison & Video
Lcd tv picture
Replace backlight lamps
Jun 03, 2017 | LG Televison & Video
LG 60PN6500-UA broken HDMI port and clicks when power on
It will most likely go away when you fix the board. I suspect there is a logic system in there looking for that port and is not finding it.
Apr 25, 2017 | LG Televison & Video
I have a LG LCD TV 42LB1DR-UA for 4 years and I am going on my second power supply. Last one was replaced less than 1 year ago. LG says there has been no recall but I can not see paying $200 per year to...
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
Aug 03, 2010 | LG 42LB1DRA 42 in. LCD Television
TV Model # C27A24T about nine or ten years old. TV
Bad grounds and bad caps will cause the problems in this tv. You will need to replace several caps and resolder the tuner itself and that means taking the tuner out in some cases and rework it. This is very time consuming and needs great care not to destroy the tuner. And reinstall the tuner to the board. You need the cap check to locate bad caps and visual to see bad grounds on any Ic on heatsinks. If you are a do it yourselfer fine.. If you cannot do this I would just replace the tv.
Oct 11, 2009 | Zenith C27A24T 27" TV
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Dec 07, 2008 | LG RU-52SZ51D 52" Rear Projection...
Open Questions:
Televison & Video Logo
91 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
