Question about Furniture
My office chair is stuck in the lowest position i cannot raise it when the lever is pulled
Posted by Mike Keller on
Tom Chichester
    Top Expert:
  • Furniture Master
  • 57,296 Answers
Possible mechanism failure
Posted on Sep 10, 2019
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Posted on Mar 09, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Posted on Dec 27, 2010
ZX2Fast
Brad Kirby
  • 547 Answers
SOURCE: stuck in park...manually pulled up
There is a park interlock solenoid that prevents you from removing the car from park without pushing the brake. It gets power from the brake light switch so as long as your brake lights work, it should be getting power. It is under the console so you would have to pull the console to replace it. Due to the cost of these solenoids, many people just block it open with a screw or zip-tie. You have to remember that if you do that, you can take the car out of park without pushing the brake.
Posted on Jun 07, 2011
gordonliber6
Gordon Liber
  • 31 Answers
SOURCE: How many levers do office chairs have?
Office chairs usually have two levers. One is used to raise and lower the seat. The other lever is used to determine theangle of the back rest.
Posted on May 29, 2012
Sam
  • 3247 Answers
SOURCE: How to release a telescoping office chair
answer already provided in a later post of this problem. Refer site
Help My Office Chair Keeps Sinking
Posted on Aug 19, 2014
Hi, my mother's mobility scooter won't work. The power button flashes constantly. Any ideas how I can fix it?
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 Power Wheelchair Break LeversMPV5 – The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
FWD and XHD power chair break releaseTEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads “Drive” and “Push”. To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
Apr 14, 2016 | Health & Beauty
What can be doene with our executive office chair as it will not remain in the raised position. After raising it, then sitting, the chair slowly sinks down? What is the problem or what can be done.
The hydraulic gas lift is broken. If you want to fix it, you will need to find/buy a replacement. This is a common problem that happens with most all chairs, even if they are rated for heavier weight/long term use, they still do not seem to last more than 1-2 years of use at the most.
Sep 06, 2014 | Serta Big & Tall Executive Chair, Black...
The information on this web page may be helpful. If the height adjustment lever is working fine then best to replace the gas lift cylinder. Help My Office Chair Keeps Sinking
Aug 19, 2014 | Furniture
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
May 29, 2012 | Furniture
What is a good height for an office chair?
office chairs range from 14.5 inches all the way up to 23inches. A good height is around 19inches. Usually chairs have a lever thatallows you to raise and lower the height as you wish.
Furniture Logo
130 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
