Question about Boating
40 lbs minnkota endura transom mount throwing in line breaker at speed number 5 only other speed are fine.
Have replaced the switch did not fix the issue.
Posted by joe baker on
john Benson
    Sergeant:
  • 184 Answers
The breaker could be breaking at less than its rated amps. The motor could have some fishing line behind the propellor. On the lower 4 speeds you have a resistor wire (its in the motor housing) in the circut, 5 hooks the battery direct to the motor and draws the highest amps. See if you can use a clamp meter to measure the amps the motor is drawing.
Posted on Oct 26, 2019
Brian Nelson
    New Friend:
    Problem Solver:
  • 6 Answers
If it just blowing the fuse at one speed or top speed it could be a short in the speed control or the negative cable is dirty. clean up the terminals and try again.
5 Related Answers
Gene Pitts
  • 159 Answers
SOURCE: Minn Kota 30 transom mount motor magnets fell out during service
Hello drummondr, please contact www.minnkotamotors.com/index.asp by E-mail attention Dave with your questions. Merry Christmas.
Posted on Dec 09, 2008
Anonymous
  • 61 Answers
SOURCE: My Hayward electric spa heater 11KW is coming on
Chances are that your element is drawing too much current. Check the manufacturer's website to make sure that you have the correct size breaker installed. Low water flow could also affect this, so make sure all of your baskets and filters are clean and clear.
Posted on Apr 05, 2009
Anonymous
SOURCE: I have a Minn Kota Endura 30, transom mount.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
Posted on Apr 17, 2009
Anonymous
  • 10 Answers
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
variste
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
What spec battery is the best for the Minn Kota 40 Endura trolling motor?
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
May 19, 2011 | Minn Kota Endura 40 Transom Mount Trolling...
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
My endura 30 lower unit was filled with water and mud/rust. It was working all speeds before I opened it up. I had to hit the lower unit sometimes to get it to spin. The armature contacts have many pits,...
You *may* be able to save the armature (about $45) by using some fine emory cloth to buff it back to life.
The brushes, seal kit, bearing, etc are about a $35-$40 bill. To have it done in-shop would be approx. $80 with labour.
Here's a schematic:
Endura 30
Good luck in your repair!
Mike
Sep 23, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Jun 18, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Boating Logo
151 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
