Question about RCA HD61W66 61" Projection HDTV
Rca hd61w66 61 inch tv, when turning on you can hear sound picture will pop on 10 seconds and then tv will cut it self off. will not stay on longer than 1 minutre
  • RCA Master
  • 8,457 Answers
Ur power BD power board have burn capacitors,buy the deflection board too,have puff up capacitors.
Posted on Sep 29, 2009
  • love_tamarra
    love_tamarra Jun 30, 2012
    is this something i can fix myself
  • Chi Chu Jun 30, 2012
    No,if u don't know the used of electronics equipments functions also must know how to do soldering works and the theory of circuitries functions of the tv too.This is just a basic diagnostic only.Tv have many variable inside it circuitries to do the exact diagnostic.But fixing these circuits boards or replacing them will have a 80 to 90 percents for the tv to functions again.
6ya staff
SOURCE:
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
Feb 12, 2009 | Curtis-Mathis CM19011 TV
My 52 inch rca tv has sound but the picture keeps popping on and off .what can be wrong with it?
2 THINGS THAT USUALLY CAUSE THIS PROBLEM IS
1) THERE IS AN ARC FROM ONE OF THE PICTURE TUBE ANODE LEADS--15.00-- THE TUBES ARE STILL GOOD , JUST THE LEAD IS BAD---NOT EASY TO REPLACE ,,YOU HAVE TO CUT THE OLD ONE OUT AND REPLACE USING SEALANT ....
2) A PART CALLLED A HIGH VOLTAGE BLOCK--75.00--THIS PART TAKES HV FROM A FLYBACK TRANSFORMER ,,,SPLITS THE VOLTAGE TO GO TO THE 3 PICTURE TUBES
KEEP IN MIND ,,IF YOU HEAR A POP--IT'S USUALLY A HIGH VOLTAGE ARCING TO SOME METAL--YOU ARE BETTER NOT PLAYING THE TV
THESE JOBS ARE BEST DONE BY TECH'S -TUNICA
Oct 19, 2008 | RCA P52926 52" Rear Projection Television
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
No picture but has sound
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA HD61W66 61" Projection HDTV Logo
377 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
