Question about Nokia Cell Phones
I have a nokia 2 mp phone and I can't receive calls - goes straight to voicemail. symbol on the screen I can't make out.
Posted by J. McClay on
  • J. McClay
    J. McClay Sep 11, 2019
    problem solved please ignore
5 Related Answers
martin hogg
  • 157 Answers
SOURCE: All my Calls go Straight to Voicemail
Here is a link to the user manual for you
http://www142.nortelnetworks.com/bvdoc/norstarbcm/t7316.pdf
Posted on Jan 11, 2008
Anonymous
  • 101 Answers
SOURCE: calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
Posted on Jun 26, 2008
Anonymous
  • 196 Answers
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Posted on Sep 07, 2008
Anonymous
  • 31 Answers
SOURCE: Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Posted on Dec 28, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Posted on Sep 19, 2009
How do I get voicemail of a Samsung s6 phone .
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
Feb 14, 2016 | Samsung Galaxy S6 Edge
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Ringing symbol on line b
When you are talking to someone, and you hang up the handset, does it actually disconnect the caller?
Apr 30, 2010 | Avaya 5400 Series 5410 Phone
Mitel 5212 no dial tone and goes straight to voicemail
Jul 20, 2009 | Mitel 5212 IP Phone
Nokia 6131 Voicemail symbol but no voicemail!
The solution is to take your sim card out of the phone, insert another sim card and switch on. After a few minutes remove this sim card and re-insert your original sim card. The voicemail symbol will now be removed.
Apr 30, 2009 | Nokia Cell Phones
Iphone can't receive calls
Jul 17, 2008 | Apple iPhone Smartphone
Phone going into voicemail
Go to:
Tools/Settings/Phone/Call, Call divert. And Cancel all diverts. If you haven't changed the security number, the default is 12345
If you change the security number be sure to remember what you change it to. It's one of the most common problems with mobiles.
Mar 14, 2008 | Nokia N95 Cellular Phone
My phone goes direct to voicemail help
Go to:
My phone wont dial out
may be ur phone is on auto ans option or on voice mail. when u use these option then phone automatically connect to voice mail. chek the setting and disable this function
Mar 20, 2007 | Nokia 6255i
Cell Phones Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
