Question about Kodak EasyShare M380 Digital Camera
Will not turn on or charge. Will not power on when hit on/off switch. Will not charge (no blinking light) when plugged in.
  • 428 Answers
Sorry, but this indicates very strongly that your battery is completely dead. To confirm this simply wipe the terminal of your battery very well and hold the terminals of the battery to your tongue. If battery is working, you should fill a sensation in your tongue at the instance of contact, otherwise you just got the confirmation you need that your battery is dead. I mean dead, not low, but dead. Change the battery.
Posted on Sep 13, 2009
My helicopter will not take a charge the remote lights blinks and the charge plugs will not turn off
If I understand well you are trying charge the helli with the power switch "on" . Turn of the switch on the helli and try charge again.
Jan 26, 2015 | World Trading 23 Hercules Unbreakable...
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
My sony vaio won't turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
My notebook is not turning on,how do i know if its the battery
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
Mar 31, 2012 | ASUS Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
Hello,my laptop didn't get started it is charging
How do you know it is charging? What does it do when you hit the power button?
Wont turn on
Mar 28, 2012 | Computers & Internet
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Jan 29, 2011 | Razor 300001-SL Ground Force Go Kart
I have a Kitchen Aid 5 speed blender. After turning it on, the red light blinks, then after choosing a speed it works, but when I hit the OFF button nothing happens. I hit the PULSE button once to stop it...
Hiya,
Sorry to hear you are experiencing an issue with your blender. We believe that the described issue indicates control board fault.
If you have KSB555, please follow the link below to show you how to replace this part on your appliance.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/HowtochangetheControlBoardonaKSB555/tabid/650/Default.aspx
https://www.youtube.com/watch?v=Lafh8UGn4No
Hope you found this useful :-)
Aug 22, 2017 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Compaq C502US Laptop Won't Boot LEDs flash
turn it off, pull the battery from the bottom, and try it again... chances are, the power adapter is not rated properly for the notebook, or the battery is dead and won't hold a charge anymore, in which case, recycle the battery.
Sep 23, 2008 | Computers & Internet
Kodak EasyShare M380 Digital Camera Logo
396 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
