Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fax like noise - Uniden DECT 6.0 Cordless Telephone Expansion Handset
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
239360
Points
557
Is this a new phone?
If it sounds like a faint fax noise, most likely you are running ADSL on the line? Those noises are from the modems talking back and forth to get internet on your phone line. Look to see if you have the line filter before the telephone... this will cut out the fax like tones.
Good Luck!
My fax sharp fo175 model problem in out going fax
Have the phone line check for noise. If the noise is loud the fax is unable to here the other fax and can not hand shake.
Can't send fax
the scan head is faulty andwill have to be replaced
2answers
Hi, we have a ricoh 3310Le fax machine that is amking a "knocking noise" anytime we recieve.
A knocking noise is typically a bad bearing, probably in the fuser. You can try lubricating the bearings (once the fuser has cooled down) and see if the noise goes away. If not, the bearings might need to be replaced in order to get rid of the noise.
1helpful
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
I can fax out but I can't receive faxes.
What happens if you dial your fax number the way you make a normal voice call? Does the fax machine pick the line up? Can you hear it making electronic noises? Do you hear any static or line noise?
Try also putting a regular phone on the fax line and attempt to make voice calls to test the lin quality. Listen for static, noise, volume issues. Report problems to your telecom company if you have trouble in voice calls.
Fax noise
-utiliy/counter
- Admin (pass 12345678)
- fax settings
SCREEN 2 (see at the right bottom of the screen), u ll have an option to turn off or lowwer the noise of your fax)
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
2answers
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
2answers
All of a sudden my drum unit/fax machine has started making a noise
take off the  two side cover, watch the gear rolling while printing you will find the noise come from, might be one of the gear is broken, certified technician will do the same thing when they troubleshoot the problem too, good luck
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
