Question about Hisense Televison & Video
Hisense tv failed flashlight test
Hisense 50k316dw turn on, shows logo and cuts to back. Failed flashlight test. When I took backcover off you can see led lights turn on then turn off.
Posted by Trish Payne on
5 Related Answers
Anonymous
SOURCE: USDTV (Hisense) DB-2010 HD Receiver failed after 1 month.
no color in picture.can someone help.
Posted on Jun 27, 2008
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Hisense TV won't turn on
see previous answer posted by me for this set.
Posted on Apr 03, 2012
gopakumarg43
  • 76804 Answers
SOURCE: No picture hisense flat screen LCD tv
Sounds like a main board fault. Contact any service technician to make it confirm. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Posted on Jan 19, 2014
gopakumarg43
  • 76804 Answers
SOURCE: Hisense tv 47" led showing half screen bright and
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Oct 28, 2014
panchal643Ja
Jayesh Panchal
  • 280 Answers
SOURCE: What's the difference between a hisense smart TVs and a hisense smart led tv
LED Smart TV saves Power and Contrast & Colour you will get better than Smart TV.
Posted on Jan 25, 2015
Hisense mod 50k316dw has no pic or sound. Tried the flashlight thing, nothing. Power light comes on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2helpful
How do you fix a hisense 50 inch tv
Take a flashlight and hold it against the screen. if you see the picture then the back light is not coming on. This is usually caused by the inverter failing. If you post the model it would help
2answers
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
How come when I turned Mt hisense TV off and when returned it won't turn back on?
Power supply components have failed. Capacitors dry out with age . You can get replacement parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
I have a LCD32W60D Hisense Television. The AV channel is now flashing 'no signal' so cannot get my dstv channels anymore - it has been fine for the last year. When I switched on today it was fine but...
Try the flashlight screen test with TV on to be sure an image is showing, hold flashlight above at an angle, if you see a faint image the motherboard needs replacing
1helpful
3answers
Black Screen
It is possible that the backplane lamps and lamp supply has failed. It is also possible that there is a failure in the power supply or on one of the circuit boards. Without doing some tests it is impossible to accurately determine the areas of fault.
Jerry G.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
