Question about Maytag Dishwashers
Why does my Maytag dishwasher go from 2:37 and then restart itself to 3:37 minutes?
Posted by TheAwsomeKid 52 on
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    How do i reset the cycle programme on my ADG 954 Dishwasher
    Hello
    Wait for five minutes if the motor stopped itself and has been stopped for less than 10 minutes. This occurs in the event of an overload. If this is the case, the dishwasher will reset itself in approximately 5 minutes.
    Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
    Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
    Repeat step 3. This will reset the dishwasher.
    Aug 11, 2011 | Dishwashers
    Dishwasher cycle "holds'
    hi there,
    check the keypad. it has a ribbon cable that plugs into the control board. it may be loose.
    Sep 23, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
    I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
    Hi jeffwirch,
    I'm Harvey the Master Plumber.
    Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
    It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
    Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Sep 13, 2008 | Maytag Dishwashers
    Flashing lights
    Turn off the power at the breaker for 5 minutes and see if it resets itself!
    If not you need hands on service!
    Sep 07, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
    Error Code dishwasher flashes 5 then 2 green light How can I reset the computer?
    TURN THE BREAKER OFF IN YOUR BREAKER BOX FOR THE KITCHEN FOR 5 MINUTES AND SEE IF IT RESETS ITSELF,THANKS-MIKE
    Jul 23, 2008 | Maytag Dishwashers
    Quick Wash cycle restarting
    Aestaie, On the quick wash cycle the machine goes through a heated rinse at 160 degrees. I think what's happening here is that the board checks the thermistor and is finding that the water is not hot enough and say's, hey, I need more time to heat this water and resets itself. The element in the dishwasher will only heat the water 1 degree every 3 to 5 minutes. So after the initial wash, there is a 2 minute drain, it fills again and there is the heated rinse. If the water is 120 and the final rinse needs to be 160, we have some heating to do here. Therefore the reset. Sounds like the dishwasher is working OK, Catriver..post back
    Apr 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
    Dishwashers Logo
    130 people viewed this question
    Top Maytag Dishwashers Experts
    Michael Thomas
    Michael Thomas
    Mike
    Marvin
    Marvin
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
