Question about Dell Computers & Internet
My monotor its all black but u can
My monitor its all black but i can steel see just a little not much and i cant get to the menu to restore this problem how do i reset the monior
  • 6,831 Answers
Hello
I got this step by step guide to reset a dell monitor i do not know if it works, but you can still try it.
Hope This can help you.
Instructions
  1. Step 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
  2. Step 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
  3. Step 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
  4. Step 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
  5. Step 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
  6. Step 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Posted on Sep 13, 2009
  • 428 Answers
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
6ya staff
SOURCE:
When tryong to install monitor the computer starts but the monitor only show fujitsu siemens logo and before I can see anything else it states no signal going to sleep. Have downloaded updated driver for...
Does the monitor have two inputs? (Digital - DVI, and Analog - VGA)
If it does, check on your monitor whether the right input is selected; there can be a separate button for input selection, or the selection can be made from the monotor's On Screen Menu.
Sep 26, 2010 | Fujitsu Siemens Computers & Internet
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
When starting the system the monotor appears to boot up- there is a flash of an HP screen, then all goes black...?
Try a different monitor and see if that fixes it - however I suspect your video card might be on the way out.
If you're familar with computers, open your case and check the card is seated properly etc. If not, take it into a store to get the card tested/try a different card.
Hope this helps,
Sherwin
Dec 20, 2009 | HP f2105 21" LCD Monitor
Black task bars
I would recommend you to install a application called TuneUp utilities which is a awesome software to restore your taskbars, broken desktops and missing files in windows operating system. Dont worry all your icons would be restored.
Sep 18, 2009 | HP Compaq FS7600 17" CRT Monitor
I need to reset the display settings but i cant see what they say
It's a simple fix. Reboot your computer and press the F8 key repeatedly until you come to a boot menu. Select Safe Mode. This will take you into Windows at a default of 640x480 resolution. Adjust the settings according to the monitor and lower them to what you had them before you did the changes.
Another method is when you are at the boot menu selection, you can select safe mode with command prompt.
Type c:\windows\system32\restore\rstrui.exe for windows xp to use the system restore and rollback windows to when it was working properly.
For windows vista type:
c:\windows\system32\rstrui.exe
Jul 27, 2009 | Acer Aspire™ T180 PC Desktop
I have a line threw my monotor and It is green and my monotor is 2 months old.
Bring or call the place where you purchased it. This should be cover by warrenty (inside 2 months). Call the co. for a RMA, Replacement order. And talk to them about the details. This shouldn't be a big problem.
Jun 17, 2009 | Acer P191WBD LCD Monitor
I have black showing on top and bottom of screen
This is a failure of the backlight circuits either the lamps or the inverters circuits are failing.This requires a return to the dealer or service center for servicing. Hope this helps you .
Apr 06, 2009 | Envision 19" Widescreen Flat Panel LCD...
MONITOR
run it in safe mode, go to control pannel find devise manager and 'roll back' the dispay option
Mar 31, 2009 | Compaq Evo N610C Notebook
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
Feb 11, 2008 | Computers & Internet
Open Questions:
Dell [email protected]^+[1][email protected][email protected] Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
768 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
