Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Petz 5 won't load
I have the same problem when loading from my hard drive (Petz 5 has encountered a problem and needs to close)
When I try to load from the CD, I get an error that says:
Sorry, Petz 5 could not run because of the following error: Asset not found. Asset =\Resource\translatinkit.txt. This may be caused by low memory or lack of hard disk space.
Note, I have over 100 MB of free hard drive space.
Posted by julnor247 on
Anonymous
    New Friend:
Try Inserting The Disk And Instead Of Loading It Go On My Computer And Petz 5 And Then Click Launch :)
Posted on Dec 08, 2009
Anonymous
Ok first try playing the game with out the disk mine worked like that and it had no errors
Posted on Sep 27, 2009
1helpful
Error Message For Petz 5
When you reinstall the game do you click 'yes' to 'do you want to save your petz'?
You need to click 'no for it for work. You will lose all your petz.. but its the only way (that i know of) to get ur game working again.
Also, when you go to play the game, go to My Computor and click on Petz5 to play, instead of playing it from the shortcut or whatever. That means you need to have the disk permentently in.
And, when you fastforward (time glitch) only forward one day at a time (opening up petz after you forward, closing, and going forward another day).
Hope it works :)
tip
How To Fix A Non-Loading Problem On Petz 5
I have written this so many times, that I decided to make a tip out of it so I dont have to keep answering the same question over and over.
To fix the problem when your loading thing doesnt load fully, and it comes up with an error message, you need to follow these instructions.
a)Save your petz to a flash drive, or CD or floppy disk. NOT to the computor as they will get deleted. (this step is only if you want to keep your petz)
b) Uninstall and click "No" to "Do you want to save your petz?"
c) Install again.
d)Put your petz back on your game, by putting the Flash Drive/floppy/CD into the computor and copying the petz files into the petz folder. (if you kept your petz)
e) Play the game from My Computor, Petz 5, Play.
You will need to have the disk in whenever you want to play for e) to work.
If this doesnt work, ith saving your petz, skip steps a), and d).
Hope this tip helps. :D
Petz 5 does not work
u have to do solve this problem then u have only two options firstly u can leave ur dogs in ur neighbour's home 4 sometime and secondly u can droped cat in park
4helpful
3answers
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
Loading on to petz5, windows tells me program has a problem
Unistall, click 'no' to 'do you want to save your petz' You will lose all ur petz, but.. ts thw only way i know that works..
Reinstall, and play the game from My Computor, Petz. play. You will need to have ur disk in whenever you want to play.
Hope i helped
Petz 5 help!
at the moment you either would have to create new petz or try installing the game again. the way to see if you saved them is to go into the saved petz folder and find files of your animals , if they are there unlock and download any zip files and they should do it for you
2helpful
2answers
Oh No
MIne does that to i am so sad!
3helpful
6answers
Loading
Sorry, Kilione, that IS what you have to do...
2answers
Won't Load
What you have to do is, re-install it, your probelm should be fixed. Worked for me!
Morgan (10)
4helpful
3answers
Dogz 5 Won't Work!
This happened to mine 2. I uninstalled it, but the folder was still there, so I went on search, local disk, and searched ubi soft then deleted it. After that it worked, except I've noticed if you press save pets when uninstalling, it doesn't work.
If I want to keep my pets, I go into the ubi soft folder, adopted petz, then I drag my pets to a new folder I make on the desktop. When the game is reinstalled, I put the pets in the folder back into the adopted petz folder.
This has been the solution for me, but I don't know if it will work for others. Good luck!
Top Ubi Soft Computers & Internet Experts
Mehandi Husain ...
Tom Chichester
Canadian VC
Canadian VC
Level 1 Expert
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
