Dryers Logo
G
Glenda Green Posted on Sep 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My touchtronic t8013c asked to check the vent and will heat up but now will not spin? how do I reset the lock out code?
Geir Lland
Level 2:
Habit-Forming:
New Friend:
  • Expert 146 Answers
  • Posted on Sep 10, 2019
Geir Lland
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
146
Questions
0
Helped
83690
Points
431
There is no lock out.
Fix the problem, then it works.
Is the drum belt broken? snapped?
Check drum motor
Miele Touchtronic Series W1113 24 Inch Front Load Washer. It does not stop after wash.
Question edited for a lot more clarity, plus add maker.
Question moved to make model category.
What does it do after wash? There are programs that do that on purpose.
Page 13 refers final spin soak, so as not to crease clothes
Page 11 refers to Wash 2 hour soak
Operating instructions Washer W 1113
Instructions Manuals https://www.instructionsmanuals.com > files PDF The laundry is not spun and remains soaking in water. This will prevent wrinkles if the laundry is not removed immediately at the end of the wash program.
https://www.google.com/search?q=miele+touchtronic+w113+does+not+stop+after+washing
I reset my convection heater and it works for a while but won't come back on until I reset it again?
Usually an overheating problem. Check any vents on the back of it and vacuum them out. Make sure the fan is spinning freely.
Full 'make model (what it is)' in all questions please, first 3 words.
Our Miele Tumble drier (Touchtronic T8013C) dries and heat fine but the 20 minutes and 40 minutes functions do not heat (only the regular drying cycle). Any one has an answer?
i don't know. first guess is regular drying cycle makes predetermined heat levels and sensor that shuts off heat and dryer when it decides clothes are dry. 20/40 minute
choices may be fan only unless there is a manual temperature control that you can set eg. off/low/med/high..
How do I fix error code AD on quietside heating system. I have no heat system won't turn on .Tried unplugging it but still start
First you have to find what the code means, then you will have to fix that problem, before it will reset! the owners manual you got with unit should tell you what the code, flashing lights or letter then number means! but off hand, check your vent, vents to see if they are clear.
Nov 03, 2016 • Dryers
Laptop fan is lod and error code on startup then quiets down
How To Fix The HP Notebook System Fan 90b Error Message On Startup?
The HP Notebook System Fan 90b Error Message On Startup indicates a serious problem which exists in relation to the heat removal process. Here, as per as HP technical support study is concerned, one of the two possible events is possible: first, the system fan is not at all spinning or even it may be the case that the system fan is not spinning properly and the second cause may be the temperature inside the case which is too high and the fan can't spin fast enough to remove the heat situation.
Steps to fix the HP Notebook fan error 90b
Step1: Working with the exterior vent
·If a user is noticing that the system fan is spinning and is blowing quite warm air from the computer, then cleaning all the exterior vents to remove dust buildup instantly by blowing air through the vent openings is necessary. This should be done while the computer is completely in "off' mode. Dust can further accumulate inside the vent opening and all around internal cooling components to prevent the heat removal process.
Step2: Perform a instant hard reset
·Performing a hard reset can further reset all the recorded thermal values in the memory by enabling you to work with the computer again even if it's only spinning for a short time to access. Save all the important files before it is in service process.
Step3: Updating the BIOS
·While updating the BIOS set-up, it may further help prevent this critical error from occurring in future as suggested by HP Notebook support
Step4: Computer servicing process
    ·Enable the computer service to easily clean up all the internal components and then replace the system fan carefully if necessary. Ensure that all the following items are well addressed while servicing
    ·Thoroughly remove all the available dust from all internal cooling components in the device.
    ·Ensure that wires from the system as well as from the CPU fans are well connected to the motherboard in secured mode.
    ·Ensure that your system fan blades are spinning correctly, and are not producing any unwanted noises. Replacing of the system fan is essential if it's not working correctly. Your above issue is now resolved completely. But do call us if you still have problem with your HP Notebooks at HP notebook Customer Support Toll-Free 1-800-213-8289 section anytime.
I have a Miele T8013C that keeps beeping with a Fault on the container. I looked in the manual and saw nothing in the directions. Can anyone help me?
Dryer spins, but no heat. vent is not plugged. when dryer spins only cold air from the vent
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 • Dryers
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
GE dryer
IF YOU HAVE HEAT & ITEMS ARE STILL WET/DAMP.YOUR PROBLEM IS WITH THE VENTING.CHECK YOUR OUT SIDE WALL CAP,VENT HOSE,IF THEY ARE CLEAR,YOU WILL HAVE TO TAKE THE FRONT OFF & CLEAN OUT THE BLOWER HOUSING & LINT FILTER AREA.
Top Dryers Experts
john h
