Computers & Internet Logo
Question about Logitech Computers & Internet
Logitech cordless headphones model #A-00006 has problem with left side can't hear any support
Posted by Varghese... on
Priscilla McDaniel
    Champion:
  • 213 Answers
Most likely it's a programming thing but it could be you have a loose wire... Never no.. Mite try getting a cheap pair try to see if the same problem occurs.. Thanks good luck
Posted on Sep 10, 2019
1 Related Answer
JESS1E
B1L
  • 9 Answers
SOURCE: Logitech cordless headphones model #A-00006 has
Hi All,
I have a
are Logitech Model # A-00006 and the wireless antenna unit is Model # A-00007.
Recently I am noticing that what is normally a stereo experience of listening while I am in on a Beacon conference call is becoming a mono experience (only the right earphone). Not sure if this is because of bandwidth fluctuations or a problem with beacon or a problem with my headset, but it doesn't seem to do it when I'm in a 1:1 call.
Odd thing is I don't hear it cutting out when I am making a direct call - only when it's a multiparty Conf call.
Thank you inadvance,
B1L
Posted on Jun 29, 2011
Logitech cordless headphones model #A-00006 has problem with left side headphone sound not coming any solution please
Hi Varghese, control the audio input connection cable on the transmitter, invert the input signals
The speaker or amplifier could also be wrong, inside the headset
Comment the results
Greetings Franco Dosil
Hola Varghese, controla el cable de conexi?n de entrada de audio en el transmisor, invierte las se?ales de entrada
Tambi?n podr?a estar mal el parlante o amplificador, dentro del auricular
Comenta los resultados
Saludos Franco Dosil
Green light keeps blinking after charging it and i turn the powere on also teh sound comes and goes from one side of the headset
Blinking green light is an indication the headset is trying to establist communications with the receiver (dongle). Sound issues are normally on the side where the microphone is, this is most commonly a broken wire. The speaker wires are very small diameter. This can be fixed by a competent soldering job with new wirest from PC board to speaker inside the headset.
2answers
Logitech cordless headphones model #A-00006 has problem with left headphone cutting out. Please help.
Hi All,
I have a
B1L
I have these logitech headphones I bought a couple years ago. I do not see a model number on them. When I use them for phone with Skype they are never loud enough for me to hear well. I have set the...
There are no drivers for headphones.And as you use this headset for couple of years the speaker performance gradually reduces.So you wont hear it properly.This normal thing.Please try changing the headset.
Thank You
6helpful
2answers
Logitech ClearChat USB Headset Model: A-00006
You can buy replacement dongles from Logitech. Don't listen to lawrenceguo
6helpful
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
2answers
Logitech speakers hissing only when headphones plugged in.
The headphone adaptors attach to your computer has a
loose connection. Use another headphone and try.
Send in your e-mail and vote for the solution. Thanks,
Logitech a-00006 wireless headphone- volume control will not work.
Hi, You might want to call the Logitech Customer Care, try on another computer, if the problem persist, then you should get a replacement for hardware failure. This is covered by warranty terms.
Thanks and have a nice day J -
Top Logitech Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
