Question about Home
Where is the time set button on the SkyScan 31420E?
3 Related Answers
David Richards
  • 569 Answers
SOURCE: SkyScan Atomic Analogue Clock # 28512
read the manual here
http://www.skyscan.info/content/manuals/15-model-28500.html
There are four buttons on the back, at the bottom. From left to right they are Pacific, Mountain, Central and Eastern
Posted on Jan 22, 2010
David Tolond
  • 2501 Answers
SOURCE: I have a model 31420E
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Posted on Dec 20, 2010
Testimonial: "Thanks for thew help. I've been able to pass it n to the young person to whom I've now given the clock. Edd"
W. T. Fickery
SOURCE: need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
Posted on Sep 24, 2013
Need a user manual for skyscan model 31420e atom travel clock
May 06, 2012 | Audio Players & Recorders
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
To Set the Time
Dec 20, 2010 | Watches
Time setting for skyscan model 88202cop , to set correct time in central zone
The clock sets itself, I have never touched mine, it just works, and unless you are sitting on a time zone, it should work. There is a set button in the back , I have never messed with it, It has an alarm on it too. Hope this helps.
Jul 17, 2010 | SkyScan 86709 Atomic Wall Clock
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 87801 how to reset time
Keep pushing the set button until dst shows on the date window then see the clock window it will read on or off press the + button for on or off.
Sep 15, 2008 | SkyScan 86709 Atomic Wall Clock
How do i set my clock
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
Sep 02, 2008 | SkyScan 86709 Atomic Wall Clock
Skyscan atomic clock
and select your zone then press set button.
Mar 08, 2008 | SkyScan 86709 Atomic Wall Clock
Skyscan model 87800
and change your wished time zone (for help go through time zone codeing list) and select your zone then press set button to normal mode and adjust the current time.
Nov 06, 2007 | SkyScan 86709 Atomic Wall Clock
Home Logo
112 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
