Question about Samsung Office Equipment & Supplies
Samsung clx-6250fx is printing blank page when I print a copy or print out, but other colors are working.i have tried all my best to fix it but nothing happened .please can anyone help me.
Atsfuny
    Welcome Back:
    Visited the website for 2 consecutive days.
Your machine most likely does not support this printing model
Posted on Sep 09, 2019
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Posted on Mar 20, 2008
Anonymous
  • 291 Answers
SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Posted on Aug 31, 2009
Stephen Lam
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
vinay229229
Vinaya Kumar Kuchipudi
  • 1121 Answers
SOURCE: I have an HP 4345
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Posted on Sep 09, 2011
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
Jan 19, 2015 | Samsung Office Equipment & Supplies
Missalignment of printer toners
Hi, you mean you could see the outline of the colors?
Feb 27, 2014 | Samsung CLX-6250FX Color Laser MFP
Samsung clx 6250fx
Clear your print heads
Sep 15, 2013 | Office Equipment & Supplies
I need a manual for the Samsung printer called 6250FX ( it has CLX before the numbers, also ).
http://www.samsung.com/uk/consumer/print-solutions/print-solutions/colour-multifunction-printer/CLX-6250FX/SEE/index.idx?pagetype=prd_detail&tab=support
Jun 13, 2011 | Office Equipment & Supplies
Brand new Samsung multi-function CLX-3175FN prints a shadow or "ghost" image in color.
Have you done a print head alignment? If yes, and that did not fix it, take it back before you warranty runs out. Most modern day electronic devices work perfect but when they don't they also do it perfectly.
The only things you can do is print head alignment and making sure when you installed those nice new print cartridges that they are pushed in all the way. To try and test anything else will cost money and since this is a brand new device it is best returned.
Aug 09, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Printing problem
Is it clean? Most ink jet printers have a simple user procedure for cleaning the print heads. You may have to clean them periodically or after the printer has been idle for a few days or weeks. If you see funny colors or print-outs are missing colors, a cartridge may be empty or a head dirty. You may have to clean a head many times to get it working again.
Jun 23, 2009 | Samsung CLX-2160N All-In-One Printer
21 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
