Here is the link to the manual which explains everything in detail.
https://www.furunousa.com/-/media/sites/furuno/document_library/documents/manuals/operation_manuals/fmd32003300_operators_manual.pdf
Of course you have to have the vector charts that you want installed or ready to install on your system.
Good luck.
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set
BEARING to “MAG” (magnetic). This will cause the unit to display course /
bearing information in relation to the Magnetic North and match magnetic
compass readings. It is not the same as True North! One has to be careful with
this setting. There are a number of areas where the earth's magnetic field is
locally disturbed, sometimes very significantly. Your GPS may not account for
it.
again, under “UNITS” I set “METRIC”.
SOURCE: furuno 1850 has water in unit, only noticed
http://www.fixya.com/support/r3771170-phone_water_damage
SOURCE: my furuno chartplotter is out about 2 km on the
Make sure your time offset is correct and also make sure you have not accidentally offset the chart. Also keep in mind that there are places in the charts that you can overzoom which can also cause this problem.
SOURCE: Where do you control the AIO?on an furuno ecdis?
https://www.admiralty.co.uk/AdmiraltyDownloadMedia/AVCS/ECDIS-Install-Guides/Furuno3000%20User%20Guide%20S-63%201%201.pdf
