Question about Canon Office Equipment & Supplies
Ir2016 is on download standby after connecting a cable it writes down connected
Posted by charles mainza on
Lenin Hudiel
    Master:
  • Canon Master
  • 913 Answers
Hi, your copier needs to be updated (Firmware)
Posted on Sep 11, 2019
5 Related Answers
moh_h86
Hany Hassan
SOURCE: error message ir2016 download standby
Error message ir2016 download standby
Posted on May 05, 2009
SOURCE: ir2016 canon xerox machine message error " downloading standby"
what is your erorcode please send me detailes
Posted on Jun 23, 2009
Anonymous
SOURCE: help
message download standby ir2016
Posted on Sep 03, 2009
canontech
Canon tech CROATIA
  • 1219 Answers
SOURCE: how can i solve error canon Ir2016 (download
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
Posted on Jun 11, 2010
Brian Achterberg
  • 62 Answers
SOURCE: canon iR2020/iR2016 error occour download
Corrupt BOOT ROM ,system software needs to be reloaded to 60.02 or higher.Tech Only
Posted on Sep 03, 2010
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
I have a canon ir2016 photocopier which can print documents directly from a computer if connected to it! I have connected it to my windows xp2 pc through a usb port but it is not detected at all. how do I...
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Sep 08, 2011 | Canon iR 2016i Black and White Copier
The iR2016 has a printer cable connection at the back. Why doesn't my iMac see this when I connect the cable via USB?
the USB port on backside of the iR2016 is ONLY for service support tool, cant be used as printer.
Aug 25, 2010 | Canon iR 2016i Black and White Copier
How can i solve error canon Ir2016 (download standby) error
Jun 11, 2010 | Canon iR 2016i Black and White Copier
When I press standby button the standby led doesn't turn on
First, make sure you have an internet connection. If so, shut down the modem. Pull out the power cable and Coax cable from the back of the modem. Then first put the power cable in, then the coax cable and then turn on the unit. Restart your computer to verify a connection. Then try to press the standby button. If this doesn't work call your internet provider and they can reset the modem remotely for you.
Good Luck.
Jul 08, 2009 | Arris SURFboard SB5120 Modem
I have a Canon IR2016 shows Download standby
sen solution me canon ir 2016J problem is dowonlod stundby not ather setting why is problem fixed send me mu brather..
Jun 23, 2009 | Canon Office Equipment & Supplies
Help
This means the printer booted in download mode. There are problem with the firmware.
You will need the support tool and a software cd for that model.
Please consult further with your manual on updating firmware or call the Canon tech to get the firmware updated.
May 28, 2009 | Canon iR 2016i Black and White Copier
23 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
