Low room temperature - Most Scotsman ice makers won't produce ice when the temperature is below 55 degrees Fahrenheit. Make sure the machine is in a room or setting that is warmer. ... Faulty thermistor - A bad thermistor usually causes the bin to fill with too much ice.
Diagnostic Codes
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
SOURCE: Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
SOURCE: Should a scotsman ice machine
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
