Question about Uniden Computers & Internet
I bought a uniden 8355+2 & the red light will not stop flashing. As soon as i plug it into the modem it starts flashing.Can you suggest what the problem could be. Noel
Posted by Noel Lowth on
Don A
  • Uniden Master
  • 2,650 Answers
A completed discharged battery yields a solid red light. A blinking red light means the battery has not yet received enough of a charge to operate the phone. You need to leave it on the charger longer, perhaps a half hour or more, for this blinking to cease.
Posted on Sep 06, 2019
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Posted on Jul 11, 2007
Buddy Mcsparrin
  • 1684 Answers
SOURCE: Just replaced power supply on cpu. When I turned
It sounds like your network card was damaged by a power surge, most likely what brew the power supply too. When you power up the PC now the network card tries to start and kills the network line going to the router, when PC is off the card does not short and the router works like it should. You should be able to put a new network card in a open slot in the pc and connect that one to your router.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
Jason
  • 218 Answers
SOURCE: red light keeps flashing
While I cannot find any reference to the flashing red light in the manual, it sounds like the amp is going into a protection mode. I would check the following items:
-Make sure you have the power wires connected to the battery with sufficient size to supply the load. The amplifier is rated for a 30 amp draw, and is fused at 60 amps (2x 30 amp fuses in parallel). I would recommend at least 8 gauge wire as an absolute minimum..and ideally larger than that. To troubleshoot this, try hooking a battery (with fuses inline, of course) with heavy gauge wire directly to the amp. Does the problem go away? If so, the voltage drop due to wire being too small is likely your culprit.
-Make sure your connections are clean. Corrosion at any point can rob your amp of the power it needs for sharp punch and proper operation. Be sure to also check wires at any other connection point. This includes fuse blocks, crimp terminals and at the battery itself. Keep in mind that corrosion does not have to be visible to cause problems. Soldering connections rather than just crimping them (when practical) can help overcome this, as can sealing connections that are exposed to road dirt and grime under the hood.
-Check the impedance of your speakers, and how they are wired. The manual goes into great detail on page 2 about how to properly wire speakers, and what ohm rating each should have. If you are using two 4 ohm speakers wired in parallel on one channel, this is too low impedance for the amp. Either split each 4 ohm speaker onto its own channel or switch to 8 ohm speakers.
While you might check these and still have a problem, hopefully these will eliminate some sources of problems outside of the amplifier itself. Good luck!
Posted on Feb 11, 2010
Anonymous
  • 26 Answers
SOURCE: red and green flashing light
TIME TO GET A PS3
Posted on Feb 23, 2010
Ted Schore
  • 7353 Answers
SOURCE: running very rough, and has
Flashing is BAD, it means theres a misfire causing Catalytic Converter damage.
Posted on Dec 10, 2010
How to dial a number on Xdect8355
If you want to make a call using the landline, first make sure that the phone is in standby and not ringing with an incoming call. Press Speaker or Home/Flash on the handset. (Both are on the left side of the handset; the speaker key is closer to the LCD screen.) Alternatively, press Home/Speakerphone on the base. Then dial the number, including the area code as needed. When you use the Speaker key, the entire call will be on the speakerphone. When done with the call press End/Clear (on the right side of the arrow keys, opposite the Home/Flash key).
This is described in the manual as the features of the keys on the base and the handset are described. The manual is available on the product page: https://www.uniden.com.au/product/xdect-8355-2/ . The current link to the manual is https://www.uniden.com.au/wp-content/uploads/OM_XDECT_8355.pdf .
I hope this helps.
(If you have paired the Uniden XDECT 8355 to a cell phone and want to use that line. Press the Mobile button then dial. (On the base, it's Mobile/Speakerphone. If you have paired the phone to two cell phones, you will be prompted to indicate which mobile device you want to use for the out-going call.)
Sep 16, 2018 | Lands Phones
Why is there a flashing red light on my Dell modem?
when you bought the modem you got a manual. look in it,
Apr 02, 2013 | Dell Computers & Internet
No solution yet for my uniden cordless dect 6.0 phone for flashing red light like a signal red light keeps flashing. how do i get it to stop?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 19, 2010 | Uniden DECT 6.0 Cordless Phone ID
Power light is red on 2wire modem
this happened to me and it turned out the power cord had gone bad. i went to radio shack and bought a new one for 35.00usd and it powered right up.
Jun 26, 2009 | 2wire (1000-000057-000) Modem
Red light that shows a message waiting won't go off after all messages have been heard and deleted.
turn it off and take out the battery?
But it could be a software problem?
May 31, 2009 | Uniden Cordless Phone
Uniden cordless phone
To reset the indicator(Red light flashing on handset), press and hold the find handset key for 5 seconds or until the light flashing stops(10 sec).
Feb 04, 2008 | Uniden Cordless Phone
Jul 10, 2007 | Actiontec (GS503AD3-01) Modem
Computers & Internet Logo
37 people viewed this question
Top Uniden Computers & Internet Experts
Marvin
Marvin
john h
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
