Question about Generac Electrical Supplies
I have a generac RS 5500 generator. I started it a couple of days aog. Turned off , now it will not start even using starting fluid
Posted by Kathy Johnston on
sherlywang
    Master:
  • 425 Answers
If you are interested in diesel generator, please contact [email protected]
Posted on Sep 21, 2019
5 Related Answers
mydogisk
Kenneth
  • 50 Answers
SOURCE: Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Posted on Apr 13, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
Anonymous
  • 154 Answers
SOURCE: I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Posted on Jun 14, 2009
Anonymous
I had this same issue with my NP 50G. I replaced the oil pressure & over heat sensor and fuel filter but the problem still existed.
After that I took the fuel bowel off the carb which had some dirt in it. Sprayed it with carb cleaner and that solved the issue. Hope this helps......
Posted on Oct 28, 2009
Anonymous
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
Portable generator won't spark.
replace the low oil level sensor pack
it controls spark
Jul 20, 2016 | Generac Electrical Supplies
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Start switch does nothing
Try the easy thing first, check connections and lube switch with mfg suggested lubricant. Sounds like a corrosion problem to me.
Nov 10, 2013 | Generac Guardian Ultra Source 15,000 Watt...
Will not start GENERAC 5500 PORTABLE GENERATOR
First you need to identify, is there a spark at the plugs? Is there fuel getting the cylinders, it can be so many things until you define at least that, the solutions are too many to list
Oct 15, 2013 | Generac 5724 GP Series GP3250 Portable Gas...
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
Mar 04, 2013 | Pramac Diesel Generator 5500 Surge Watts,...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Apr 16, 2009 | Hammering
Electrical Supplies Logo
123 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
