Question about Asko Dishwashers
ASKO D3120 built in diswasher, water at the bottom is not draining.
Posted by Lien Trinh on
rmaazar
    Problem Solver:
  • 13 Answers
Has the garbage disposal been replaced recently?
- check that the drain plug on disposal s popped out
https://www.hometips.com/wp-content/uploads/2012/05/remove-dishwasher-plug.jpg
check that the drain line has a loop in it, i prefer the high drain loop.
http://jbch.us/uploads/3/4/3/0/34305337/dwhighloop1500_orig.jpg
Posted on Sep 06, 2019
5 Related Answers
Priya darshan
  • 3422 Answers
SOURCE: Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
Anonymous
SOURCE: I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Posted on Aug 17, 2008
Anonymous
SOURCE: water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Posted on Dec 20, 2008
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: my diswasher does not drain properly and the cycle
The ONLY way to get the water out is to bail it out and then soak the rest up with a large towel. Not a pretty solution, but an honest answer. I hope this helps you!
Posted on Aug 14, 2009
mike kennedy
  • 146 Answers
SOURCE: I need to replace the
asko is a hard one to get generic parts for,, if you will have any luck repair clinic.com will be your best bet
Posted on Jan 19, 2011
Asko D5424 water not going in to diswasher
sounds like the water inlet valve is not working. it is not real hard to replace.
Jun 01, 2014 | Asko 24 in. D3120 Dishwasher
Goodluck,
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Doesn't shut off
i think you are hearing the drain pump going. take the bottom front panel off so as to expose the bottom tray. yoy willprobably find this full of water. mop water out and it should work. if fault reoccurs then you have a leak.
turn power off first
Sep 02, 2008 | Asko 24 in. D3120 Dishwasher
Drainage Problems
Turn off the dishwasher by pressing the on/off switch on the top left of the dishwasher. Wait 5 seconds. Press and hold the program button on the right side of the front of the dishwasher. As you are holding the program button, press the on/off switch again. Release both. This should reset the machine
Apr 13, 2008 | Asko 24 in. D3120 Dishwasher
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
146 people viewed this question
Top Asko Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
