Hi Hoyt, clean the readers' lenses, with a cotton swab subtly soaked with a drop of isopropyl alcohol
If you use it with batteries or batteries, check that they are in good condition
Always test with original discs, this way you will know if the Laser reader still has the ability to work
If after these tests, you cannot read, consult a technical service specialized in Walkman
Discuss models of Sony players
Greetings Franco Dosil
Hola Hoyt, limpia las lentes de los lectores, con un isopo de algodon mojado sutilmente con una gota de alcohol isopropilico
Si lo usas con pilas o bateria, controla que se encuentren en buen estado
Siempre prueba con discos originales, de esta manera sabras si todavia el lector Laser tiene capacidad de trabajo
Si despues de estas pruebas, no llega a leer, consulta con un servicio tecnico especializado en Walkman
Comenta los modelos de los reproductores Sony
Saludos Franco Dosil
SOURCE: Blinking "disc" error
another thing to do is listen to the unit as it spins up, you may be able to hear the disk spinning (though you can definitly see it if you open it up) and you should also be able to hear the mechanism that moves the optics allong the rail. If you hear that but still no read, you might try opening up the case (6 small phillips screws and then a small bit of prying to open) and look to see if the small thin plastic wireing harness is fully seated in the connector on the main board. If not loosen the small brown retaining clip and push the plastic strap with the traces fully into to connector and push the retaining clip back in. I have fixed 2 d-nf420 units this way.
SOURCE: Sony Walkman D-NE004
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
