Question about Dirt Devil Vacuums
I bought this dirt devil 3 in 1 three weeks ago. Yesterday it suddenly made a squeeck sound an since then it sounds totally different than it was before. It is still working but do not suck strong as before. Is it normal that it is getting warm after I use it for a short period?
SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
Posted on Jan 06, 2008
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
Posted on Apr 04, 2009
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Posted on Apr 08, 2009
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
SOURCE: Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Posted on May 05, 2009
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Apr 21, 2011 | Dirt Devil Bd20045 Stick Vacuum
Mar 17, 2011 | Dirt Devil Vacuums
May 12, 2010 | Dirt Devil Featherlight Bagless Upright...
Jan 30, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Jan 10, 2010 | Dirt Devil Carpet CPR Vacuum
Nov 27, 2009 | Dirt Devil Featherlight Bagless Upright...
Jul 01, 2009 | Dirt Devil Vacuums
May 13, 2009 | Vacuums
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
141 people viewed this question
