Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf - prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time.y in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.Select Restart [F4].I hope this help don't forget to rate this post : - )
