Question about Samsung Office Equipment & Supplies
I INSTALLED A new black toner cartridge AT Samsung clx-6250fx BUT when i printing black document color or making a black photocopy IS PRINTING BLANK PAGE but the color page is printing
chiraagbhatt
  • 3 Answers
Did you take a test print after installing the new cartrige in your printer that is the first thing to do always.
Posted on Sep 05, 2019
Testimonial: "Yes, I did test after installation the black toner cartridge and the results on the page it's showing the other colors but without black color. I thought that maybe it's the toner cartridge that I did replace. I have two new toners for black cartridge I put another new toner again and still I'm receiving the same result the black toner it's not printing."
  • chiraagbhatt Sep 05, 2019
    The Cartridge are stocked once or newly purchased recently.
  • Anonymous Sep 05, 2019
    no are not stocked at once
alienlogic_s
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Its not meant for photography, since many are too dark, thats why it prints black
5 Related Answers
Anonymous
SOURCE: kodak 5100 no black printing, light on colors
Had the same issue... No black ink. Called the # from "Solution #1" guest, 18004216699. Had to patiently go through all the basic trouble shooting stuff like calibration, print head clean, demo print, etc. Once I went through that, they issued me a new print head for free, no shipping charges or anything. Just did this today, but they say I should have the print head in 3 days.
For once, service worked like it should!
Posted on Jul 19, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Stephen Lam
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: printing blank pages
    For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
    Posted on Apr 09, 2010
    Samsung clx 3185 printing is all faded, colors and black
    When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
    Jan 19, 2015 | Samsung Office Equipment & Supplies
    Missalignment of printer toners
    Hi, you mean you could see the outline of the colors?
    Feb 27, 2014 | Samsung CLX-6250FX Color Laser MFP
    Faded prints samsung clx3185 fw
    Got one clx 3185fn printing black only. even press color copy button.
    Cartridges are new. Please advise.
    Thanks
    [email protected]
    Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
    Clx 3175fn says "toner low" and won't print. but I
    If is attempting to print the documents remove the cartridges and check to make sure they were properly installed. Make sure that the tape was removed that covers the ink and that the cartridges "click" into place when installed.
    Mar 01, 2011 | Samsung Office Equipment & Supplies
    How do i override an empty color cartridge so that I can atleast print in black?
    There is an error in the control logic of the printer that you can exploit like this:
    1. Start printing your document, you will receive the error message "missing toner"
    2. open the front door and close it again, this will reinitialize the test cycle
    3. the printer will now print one page before verifying the toner content again
    4. after one page you get the"toner empty" message again. Reopen the door and close it again to print another page.
    This is only an emergency workaround if you really need to print something black urgently, in the long run you still have to buy a new toner.
    Apr 15, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
    Printer is a Samsung CLX 3175FN. It says the
    To run a quick check on your black toner, insert your old black toner back to the printer.
    press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
    get the new toner with the box packing back to the shop for replacement.
    Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
    Printing problem
    Is it clean? Most ink jet printers have a simple user procedure for cleaning the print heads. You may have to clean them periodically or after the printer has been idle for a few days or weeks. If you see funny colors or print-outs are missing colors, a cartridge may be empty or a head dirty. You may have to clean a head many times to get it working again.
    Jun 23, 2009 | Samsung CLX-2160N All-In-One Printer
    Light lines down middle when printing black
    try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
    let me know wat happen Regards
    I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
    Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
    41 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
